bad injectors? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 05-24-2011, 09:20 PM Thread Starter
97Stroker13's Avatar
bad injectors?
when i was driving my truck today i noticed a major power loss. While i was slowing down to make a left, turn the idle dropped, and got really sloppy. It was idling very rough and had no power. i looked to the see if the CEL came on, and it didnt. I drove it all the way home and it never came on. When i got it home, i popped the hood while it was running, and noticed that the "knocking" was harder on the passenger's side than it was on the driver's side. Im not sure if there was something in the fuel lines that may have clogged the injectors. The previous owner said that he had to drop the rear fuel tank becasue of bad diesel one time. Not sure if this is the same problem. Im gussing it may be an injector problem. It is not my lift pump, i replaced that a few months ago.
What do you guys think?
Thanks, brandon
1997 Ford F-250 SCLB
1.00 A/R exhaust housing
TS chip w/ Swamps tunes
6637 intake
4 inch turbo back exhaust
Single disc converter,billet backplate
B&M Trans cooler
BTS valve body w/transgo shiftplate
Wicked wheel 2
Adrenaline HPOP
Swamps diesel 160/100%'s
Irate E-fuel
97Stroker13 is offline
post #2 of 14 (permalink) Old 05-24-2011, 09:50 PM
Re: bad injectors?
Check all the connections to the UVCH.
02 f250
countryboyrob is offline
post #3 of 14 (permalink) Old 05-24-2011, 09:58 PM Thread Starter
Re: bad injectors?
what and where is that located?
6637 intake
B&M Trans cooler
Wicked wheel 2
Adrenaline HPOP
Irate E-fuel
post #4 of 14 (permalink) Old 05-24-2011, 10:02 PM
jimdawg185's Avatar
Re: bad injectors?
On the valley side of the valve cover. Large harness plugs into the cover gasket.
jimdawg185 is offline
post #5 of 14 (permalink) Old 05-24-2011, 10:03 PM
Re: bad injectors?
Top of the motor by the valley, you will see the clips hooked up right below the valve cover. There is 4 wire's per clip, I'm only guessing that maybe one of the clips came off or a bad wire. It's easy to check those and rules out wiring to the harness.
02 f250
post #6 of 14 (permalink) Old 05-24-2011, 10:17 PM Thread Starter
Re: bad injectors?
just checked asll of them, besides a little oil, theyre fine, all have good connection.
6637 intake
B&M Trans cooler
Wicked wheel 2
Adrenaline HPOP
Irate E-fuel
post #7 of 14 (permalink) Old 05-24-2011, 10:27 PM
bad12jr's Avatar
Re: bad injectors?
Could have a wire rubbed through under the valve cover. Had a buddies do similar. Any smoke. Also you can unplug the front plug on the passenger and start it. See if it runs different then plug it back in and do the back.
1996 F250 ext cab XL 5spd
Gearhead 6 pos, 3" dp to 5" Tailpipe, 6637, Sunpro gauges, SD AD's, T500 HPOP, SD Electric Fuel, 3" Plenums 300hp 500ft/lbs
bad12jr is offline
post #8 of 14 (permalink) Old 05-24-2011, 10:31 PM Thread Starter
Re: bad injectors?
no smoke at all, what will this tell me? ill try it.
6637 intake
B&M Trans cooler
Wicked wheel 2
Adrenaline HPOP
Irate E-fuel
post #9 of 14 (permalink) Old 05-24-2011, 11:54 PM
Re: bad injectors?
I'm having exactly the same problem, however; I'm loosing oil quickly at times... It will be interesting to see what you do as I am debating on upgrading everything...
oldschoolstrokerr is offline
post #10 of 14 (permalink) Old 05-25-2011, 12:42 AM Thread Starter
Re: bad injectors?
i tried it, nothing.
Thanks though man anything helps.
6637 intake
B&M Trans cooler
Wicked wheel 2
Adrenaline HPOP
Irate E-fuel
