d60 front axle conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 52 (permalink) Old 05-24-2011, 03:59 PM Thread Starter
I know this has been talked about alot, but without purchasing a Reverse shackle kit, Can you install: d60 spring, cross arm, steering linkage from a 95 f350 into a 96 f250 ttb? I know that it is going to ride rough, but will it be safe and reliable?
thanks.
dmoon is offline
post #2 of 52 (permalink) Old 05-24-2011, 04:10 PM
Re: d60 front axle conversion
Yes. You don't need to do a rsk unless you wanna run superduty springs. Using f250 ttb springs will give you the roughest ride.
02 f250
countryboyrob is offline
post #3 of 52 (permalink) Old 05-24-2011, 04:17 PM Thread Starter
but if i use the 95 f350 springs would be ok.?. the RS kit looks nice, but its a truck. is the way i look at it. maybe some day the RS kit would be a nice addition
dmoon is offline
post #4 of 52 (permalink) Old 05-24-2011, 04:38 PM
Yes it will be fine. The rs kit is not needed unless you wanna run springs from a SD.
02 f250
post #5 of 52 (permalink) Old 11-21-2011, 02:13 AM
BROKE as a JOKE
MAN im glad i've been searching and reading. THANK YOU rob, i will be doing a straight D60 swap w 350 springs
2015 F-350 CCSB King Ranch
6.7 PowerStroke, 3.55 LS, 4x4
stupid_rope is offline
post #6 of 52 (permalink) Old 11-21-2011, 02:45 AM
krisx125's Avatar
I just did the swap using the RSK and SD leafs..Isnt the RSK designed for obs leafs? I had to cut the spacers out of the kit to move it 3.5 inchs forward to make room for the sd leafs.
Kris
1997 F250 7.3 5speed, Valiar clutch, guages Boost, Water temp, EGT, 130k miles, 3" DP, 6637 filter.
2007 F350 King Ranch, All STOCK 25k miles.
2002 F-450 zf-6 4X4 Flat bed 60k
1983 F250 5.8L plow truck
krisx125 is offline
post #7 of 52 (permalink) Old 11-21-2011, 02:47 AM
Just finished the swap on my 95 F250 w an axle from a 92 F350. Went fairly easy, did it by myself. Did swap brakelines and driveshaft. Still need to swap out transfer case yokes, tomorrows job.
cooter is offline
post #8 of 52 (permalink) Old 11-21-2011, 03:19 AM
BROKE as a JOKE
cooter where'd you find the axle?
post #9 of 52 (permalink) Old 11-21-2011, 03:29 AM
Bought a complete parts truck. Will probably swap the rear block also. Not sure, the 95 F250 sits pretty high in the rear as is with some extra leafs.
cooter is offline
post #10 of 52 (permalink) Old 11-21-2011, 12:29 PM
BROKE as a JOKE
That's the way its looking for me. found a 95 350 with a newer (120K on it) motor for 1,000.
i cant see paying 4 figures for a used axle and springs
