drw to srw conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-24-2011, 03:48 PM Thread Starter
95 f350 10.25 sterling dual rear axle. can i convert this to a single rear wheel axle?? and how?
Thanks
dmoon is offline
post #2 of 10 (permalink) Old 05-24-2011, 04:13 PM
Re: drw to srw conversion
Just take off the two outside tires and be done.
02 f250
countryboyrob is offline
post #3 of 10 (permalink) Old 05-24-2011, 05:33 PM Thread Starter
by doing that will the rear wheels track the same as the front wheels assuming they are all single rear wheels?
thanks.
dmoon is offline
post #4 of 10 (permalink) Old 05-24-2011, 05:40 PM
I don't see why it wouldn't track the same as long as you are running a srw wheels, my first post should have included this but standing in line at taco bell didn't give me enough time.
02 f250
post #5 of 10 (permalink) Old 05-24-2011, 06:13 PM
I'm not sure about on the Sterling rear axle, but I do know on Chevy's, the WMS to WMS mounting width on the rear axle is different. Best thing to do, in my opinion, would be to find a SRW axle. They're dime-a-dozen.
gijoe4500 is offline
post #6 of 10 (permalink) Old 05-24-2011, 06:51 PM
I believe they are the same but the drw have longs studs
02 f250
post #7 of 10 (permalink) Old 05-24-2011, 08:49 PM
STILL LEARNING
Bradbilt's Avatar
Are you talking pick-up or cab-n-chassis?
If you are talking about taking a DRW pick-up and making it a SRW oick up, you need to change the COMPLETE rear axle. The DWR axle is 6" wider than a SRW pick-up axle.
For the front, just pull of the front hubs and swap them for a regular D60 or a D50 hubs
If you are talking c-n-c DRW to a SRW, IIRC the c-n-c axle is VERY close to a SRW pick-up axle but not quite. can remember if it was wider or narrower
Bradbilt is offline
post #8 of 10 (permalink) Old 05-24-2011, 10:51 PM Thread Starter
guess, I'll do some measuring tonight! will reply with results
dmoon is offline
post #9 of 10 (permalink) Old 05-24-2011, 11:25 PM
Millerfarms's Avatar
What diesel brad said if it's a pickup dually axle is from 4 to 6 inches wider
83 f250 460 4x4 4spd ,dana 60 front axle,3;55s ,502ci scj
97 f250 4x4 ccsb,ford cummins,nv5600,271 t case,dana 60, dana 80 , looking for obs cc grey door panels
95 f250 4x4 rclb 4" lift on 35s
Millerfarms is offline
post #10 of 10 (permalink) Old 05-25-2011, 01:14 PM Thread Starter
Results: Pickup dually. its about 5.5" wider.
guess i'll just be changing the gears in mine.
Thanks for all the help guys!
dmoon is offline
