Truck is starting harder - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-24-2011, 02:14 PM Thread Starter
Bergy1's Avatar
Recently my truck is turning over slower. It has been anywhere from 40 to 70 when this has occurred. It doesn't seem to matter if it has been sitting for a day or two or short time (it may be a little worse after sitting for a day or two). It has been puffing a little more white smoke when it starts.
My batteries read 12.29 volts after sitting for a day. and 12.9 volts after running for a couple minutes. I separated the batteries and they both stayed around 12.8 (truck off).
Does the voltage sound okay?
Is this a sign of the starter getting weak?
Thank you for any help.
I replaced the glow plugs 6 months ago and put on a Stancor relay
1997 F-350, Crew, 7.3, LB, Centurion package. Napa intake, MBRP exhaust, Built tranny, Stage 1.5 from Rosewood, T-500, 6 Pos chip from PHP, EBPV delete, gutted pedistal, Tranny Temp, Boost, & Pyro.
Bergy1 is offline
post #2 of 6 (permalink) Old 05-24-2011, 03:04 PM
Zrock's Avatar
Re: Truck is starting harder
Sounding like starter. Min was similar if it sat for anything over a hour or 2 it got slower to start... The Starter was the last thing i changed... Alternator, batteries and finally did the starter. :)
Zrock is offline
post #3 of 6 (permalink) Old 05-24-2011, 03:35 PM
95powersmoker's Avatar
If it's cranking over slowly, I would put a new starter in it. Makes a world of difference. I went through the same thing this last summer..
That voltage while running should be a little more I would think after the glow plugs and everything turn off.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #4 of 6 (permalink) Old 05-24-2011, 04:48 PM
OBS Addict
7.3psd97444's Avatar
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #5 of 6 (permalink) Old 05-24-2011, 06:39 PM
OverkillMotorsports's Avatar
Have your batteries tested individually at the auto parts store and then if they pass go with a starter
1995 Ford Powerstroke F-250 4x4
Regular Cab Dually on 44's
OverkillMotorsports is offline
post #6 of 6 (permalink) Old 05-25-2011, 02:39 AM
Indeed, voltage while running should be higher, but don't bother checking until after you know the glow plugs have cycled off.
madpogue is offline
