Where to buy EBPV Tube? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 05-24-2011, 12:46 AM Thread Starter
OK so in prepping the new engine, I pulled the ebpv tube to clean and put back and as I was spraying brake cleaner down the tube, I noticed a nice steady stream shooting out the side!
I've searched a few places online and cant seem to find one, It looks like a regular 37degree flare, could I use some braided stainless hose and AN fittings? or would it be too hot?
TIA
loudmouth is offline
post #2 of 13 (permalink) Old 05-24-2011, 02:14 AM
Re: Where to buy EBPV Tube?
TIA
Where is the tube located in front or behind the HPOP reservoir?
Exhaust Back Pressure Tube
(Ford) F7TZ-9D477-A (94.96 earlier models, behind of the reservoir)
(Ford) F7TZ-9D477-AA (97-up; later models in front of reservoir) but in some case it may mount like earlier models, so you have to check where is, to get the correct # part.
I also have this # part but I dont know which of those are:
Dorman # 598-104 (Rockauto)
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #3 of 13 (permalink) Old 05-24-2011, 02:17 AM
Patrick Feeley's Avatar
Here are some part numbers (Stroker #1 beat me to it):
Exhaust BackPressure Sensor Tube (sometimes called an EGR tube in aftermarket under Emissions stuff)
(Ford) F4TZ-9D477-A, (International) 1821793C1, (Dorman) 598104 (94-Feb 97; mounts on bracket above/behind oil reservoir)
(Ford) F7TZ-9D477-AA, (International) 1830933C1, couldn't find a Dorman cross for this one (Mar 97-end 97; may mount in front of reservoir)
I would try your local parts place or RockAuto for the Dorman number (earlier tube and its about half the price of factory) or "Tousley Ford Parts Depot" for the factory numbers. Cheers!
Patrick Feeley is offline
post #4 of 13 (permalink) Old 05-24-2011, 02:55 AM
just learning...
96'BigBlue's Avatar
yep Autozone, Napa, Advanced auto prolly carry it but will need to order it
1996 f350 dually AFE Intake, Gauges, SuperChips Programmer, Auxillary tranny cooler& fan, IC, DP only.... 299,000 an still rollin.....kinda...
2000 F250 XLT-bone stock and staying that way
96'BigBlue is offline
post #5 of 13 (permalink) Old 05-24-2011, 04:50 PM
OBS Addict
7.3psd97444's Avatar
^ what they said.
....BUT, IMHO you should consider maybe deleting the ebpv.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #6 of 13 (permalink) Old 05-24-2011, 05:15 PM
OBS junkie
Cat_Rebel's Avatar
We're talking about the tube that runs from your pass side exhaust manifold to the top front of your engine & sits by your HPOP. Are you talking about that or the butterfly on the exhaust side of the turbo?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #7 of 13 (permalink) Old 05-24-2011, 05:21 PM
Busy Busy
Marty's Avatar
Makes your own. Tube can be damn near straight coming across front of engine.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #8 of 13 (permalink) Old 05-24-2011, 07:50 PM
fordnut's Avatar
yeah i made my own if you have the engine out its even easier
anybody want a cheap dana 60 front
fordnut is offline
post #9 of 13 (permalink) Old 05-25-2011, 04:23 AM Thread Starter
What size are the fittings to fabricate your own?
post #10 of 13 (permalink) Old 05-25-2011, 04:39 AM
OBS Addict
Oh I see. When I saw 'ebpv' it threw me off. Lol
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
