Can it be fixed? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 05-23-2011, 03:50 AM Thread Starter
I aim to misbehave
chromehound's Avatar
Can it be fixed?
Had a little oops on my radiator long ago and had to do late night garage trama surgey I've replaced the radiator but if this can be fixed I'd like to keep it for a spare but being plastic in the corner I don't know if I could tap it and thread something in, so any ideas would be great.
chromehound is offline
post #2 of 11 (permalink) Old 05-23-2011, 03:57 AM
Harl
Harl's Avatar
Send a message via AIM to Harl
Re: Can it be fixed?
Is that for the over flow?? If so I broke my buddys off workin on injectors one time lol.
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
Harl is offline
post #3 of 11 (permalink) Old 05-23-2011, 04:02 AM
Running at last...
powerstroke cowboy's Avatar
You might be able to clean it up a plastic weld it..
97 CCLB 4x4 ZF6 [email protected]
powerstroke cowboy is offline
post #4 of 11 (permalink) Old 05-23-2011, 04:15 AM Thread Starter
I aim to misbehave
Yup I slipped off the stool taking the belt off so now I unhook the hose to avoid this problem.
Plastic weld? As in an epoxy or like what they do to quad bodies?
post #5 of 11 (permalink) Old 05-23-2011, 04:20 AM
Fixing Broken Stuff
toolmangary's Avatar
That looks ugly, If it was mine I'd be buying a new one.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #6 of 11 (permalink) Old 05-23-2011, 04:43 AM Thread Starter
I aim to misbehave
Already done and in but that little repair lasted ~3.5 months and 3,000 miles, the goo is from when it started really leaking after my trip to CO.
post #7 of 11 (permalink) Old 05-23-2011, 03:42 PM
Cratos's Avatar
rad shop can change the top of the tank been there done that I tried a napa rad but made in china :) and got it half full and it was leaking. pulled it back out. and took my old one up town to lacal rad shop :) all fixed.and saved 200.00
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #8 of 11 (permalink) Old 05-23-2011, 04:23 PM
Harl
Harl's Avatar
How much did it run to have it fixed?
Cody,17
Harl is offline
post #9 of 11 (permalink) Old 05-23-2011, 04:27 PM
All done now
Arisley's Avatar
Clean it all up, cut it off, make a nice clean hole and put in a bulkhead fitting. Might work.
Arisley is offline
post #10 of 11 (permalink) Old 05-23-2011, 04:33 PM
Radiator shop should be able to get you a tank.
E99 2wd (05 4wd conversion in process)
DIY intake
PMT 1 PCM
5" Magnaflow Exhaust
NLTD Tunes
05+ trans cooler
DIY D66 by Barder Turbo service
bryan.d is offline
