97 350 PS just started running ruff?? Only 85k - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-21-2011, 04:26 AM Thread Starter
"Jesus Still Loves You"
My 97 F350 CC with 85,000 on it just started running ruff today. Ruff idle and when under load. Never seems to clear up. I'm new to the diesel market so I know very little about what to look for. Any ideas where to start? I guess I'll start with the fuel pressure. I just installed a new fuel filter last week, good that have anything to do with this?
speedy_fisher3 is offline
post #2 of 6 (permalink) Old 05-21-2011, 12:57 PM
Moderator
PsRumors's Avatar
Re: 97 350 PS just started running ruff?? Only 85k
I'd pull codes first just to see.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #3 of 6 (permalink) Old 05-21-2011, 09:43 PM
fordnut's Avatar
or ya got some crappy fuel
anybody want a cheap dana 60 front
fordnut is offline
post #4 of 6 (permalink) Old 05-21-2011, 10:03 PM
Bugman's Avatar
I would guess the under valve cover harness. You can unplug one of the plugs on the valve covers and see if it changes how it runs. There are two on each valve cover and each one controls two glow plugs and two injectors. If you unplug one of them and how it runs doesn't change you have found the problem area and then you can pull the valve cover and investigate further.
Bugman is offline
post #5 of 6 (permalink) Old 05-23-2011, 02:22 AM Thread Starter
Ok thanks gang, I'll try that tomorrow and see what I find out. Thanks again
post #6 of 6 (permalink) Old 05-26-2011, 02:11 PM Thread Starter
Man, that was simple. One of the wires going under the valve cover had come unplugged. Pligged it back up and zip tied it so it can't vibrate loose again and it runs like a new one again.
