Alternator connections - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-20-2011, 08:34 PM Thread Starter
DieselAddict
j.soffa's Avatar
What are the two connections on the top of my alternator. I'm trying to trace a problem and that information would be helpful! Thanks!
1995 F350 7.3L T444E (not powerstroke) Stage 2 Inj, Terminator HPOP, TS 6-pos.
j.soffa is offline
post #2 of 4 (permalink) Old 05-21-2011, 03:59 PM
Re: Alternator connections
http://
The light green with red trace wire goes to cluster and is the ignition excite circuit
The short single plug is an indicator for dash lite and if loose or unplugged or if alternator fails should come on, I think but I don't understand how it works. WB= white and black colour.
The other wire that hooks to main power feed don't know....(circuit 36) VW=violet and white colour
Someone I'm sure will be able to better explain.
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #3 of 4 (permalink) Old 05-21-2011, 08:32 PM Thread Starter
DieselAddict
j.soffa's Avatar
exactly what I needed! thanks a bunch!
j.soffa is offline
post #4 of 4 (permalink) Old 05-22-2011, 03:21 AM
Glad I could assist let us know how you make out...
jrc
JCart is offline
