Fuel pump banjo bolt, I found the right wrench. Tips on reassembly. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-20-2011, 06:56 PM Thread Starter
velocejoe's Avatar
Craftsman makes a 32MM open/closed end wrench that fits the banjo bolt perfectly, no welding, modding, etc. Just used a 3Lb hammer to hit the wrench to break the banjo bolt loose.
I noticed that after 1000 miles or so after reassembly, the banjo bolt seemed to have loosened up a little, as well as a couple of the FORD SPEC hose clamps which I bought new along with FORD SPEC fuel hose. So, just make sure you check all clamps and bolts after replacing your fuel pump or after rebuilding/removing fuel bowl.
I just hope the hose clamp on the bottom of the fuel bowl line that you can only reach once it's out, is not going to loosen up.
95 F350 OBS Dually, 2wd, LB, EC, 5SPD 310K!
New: Clutch, Fuel Pump. CCV MOD, FB Rebuilt, 3" DP, Tyler Performance Cold Air Intake, Rebuilt Oil Cooler, Used turbo just installed with 90K. 15.5 MPG pulling one-car trailer loaded.
Appears all original. Not even burning oil!!!
velocejoe is offline
post #2 of 2 (permalink) Old 05-20-2011, 07:14 PM
psdguy97
psdguy08's Avatar
Re: Fuel pump banjo bolt, I found the right wrench. Tips on reassembly.
Mine hasn't loosedned up and i put 2000 on it so far. I better check it just to be safe now. lol
95 F-250 ECLB
6637 air intake, 3 inch dp to 4 inch exhaust, EBPV delete, ccv mod, glowshift gauges ( fuel pressure, boost, trans temp, pyrometer ) Dp tuner ( no start, stock, 80hp econo, 60hp tow)
Cobra 29 classic w/nightwatch, Wilson 1000 magnet mount, weather guard backrack, code 3 lightbar.
psdguy08 is offline
