4WD High to Low - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 05-20-2011, 02:08 AM Thread Starter
4WD High to Low
I looked and looked for a thread for problems shifting from 4 wheel high to low. I know a couple other OBS guys that have the same issue. I can shift easily from 2WD to 4WD hi but cannot put it in 4WD low. WTF? I remember having to push the shifter down to put it into lo but it will not push down and let me put it in low. It's kinda stiff going from 2 to 4 but nothing too bad. Is this something that needs a whole new shifter and linkage or can this be remedied?
Facebook Jamie Murphy
1997 F250 4X4 Supercab Long Box
Current Mods:
FPR Shim
AirMax Flow Systems Cold air intake
Napa 6637 Air Cleaner
Dual 5" Mitre Cut Stacks Straight piped
BFG Mud Terrain 35X12.5X17
CenterLine Polished Aluminum Wheels
MBRP 3" DownPipe
Built in Leaky Windsheild
Irishcream is offline
post #2 of 15 (permalink) Old 05-20-2011, 02:19 AM
One of a kind
PSD-BLACK-CLOUD's Avatar
Re: 4WD High to Low
Is the truck in nutral when you try to put it in low?
2010 F-350, Auto,4X4, 4dr long bed, SCT/Gearhead, S&B, High Idle,Guages:boost,egt,trans, 2.5" Leveling Kit/Track Bar, PMF bars, 325-60-20's on 20x10 XD Revolvers
PSD-BLACK-CLOUD is offline
post #3 of 15 (permalink) Old 05-20-2011, 02:53 AM
gnxtc2's Avatar
Re: 4WD High to Low
Check that pivot sleeved is not siezed/oxidated on xfer case. It's where the shiftet lever is attached to.
If I remember, I'll take a pic tomorrow.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #4 of 15 (permalink) Old 05-20-2011, 06:05 AM Thread Starter
Re: 4WD High to Low
yes, neutral, in gear , running, not running. everything. I went underneath to have a look but couldn't figure out what was seized. tough when you don't know what to look for.
Current Mods:
FPR Shim
MBRP 3" DownPipe
post #5 of 15 (permalink) Old 05-20-2011, 10:25 AM
excavator's Avatar
Re: 4WD High to Low
on my mason dump that we snow plow with it rusted bad and I just used hack saw and cut the lock pin off an now I don't have to push it down.
Works perfect but just can't pull back too fast as there is no locl out any more.
I like it and the shift dedents in transfercase are still felt when you shift it. This fix took me about a minute as I never took anything off truck to cut the pin as you see in my pics. Yours may not be as bad as mine and you may be able to take apart the slider and lube it up but after years of this problem I decided enough of the push down lock out and time to remove it. Should have cut pin off a few years back and saved some aggivation.
96 F250 XLT 4x4 210000 miles Dana 60, Baby Swamped,Tony Wildman tunes,AutoMeter Pyro Boost Trans ,DPP downpipe,Tymar intake BTS TRANS
e99 f350 cc/lb drw php hydra plus Tony Wildman tune
excavator is offline
post #6 of 15 (permalink) Old 05-20-2011, 12:29 PM Thread Starter
Re: 4WD High to Low
What a good idea, never would have thought of that. Is it solid enough to keep still while going over some rough stuff?
Current Mods:
FPR Shim
MBRP 3" DownPipe
post #7 of 15 (permalink) Old 05-20-2011, 05:08 PM
excavator's Avatar
Re: 4WD High to Low
sure is as the dedents are still in transfer case
post #8 of 15 (permalink) Old 05-20-2011, 06:58 PM
STILL LEARNING
Bradbilt's Avatar
Re: 4WD High to Low
Im sure this
is seized up on you. It would be wise on your part to take it off, then apart, clean and lubercate it. BEFORE you brake the $175 cast aluminum and have no shifter.
I went overboard and added grease fittings to mine
Bradbilt is offline
post #9 of 15 (permalink) Old 05-20-2011, 11:22 PM Thread Starter
Re: 4WD High to Low
what did that assembly cost you?
Current Mods:
FPR Shim
MBRP 3" DownPipe
post #10 of 15 (permalink) Old 05-20-2011, 11:30 PM
gnxtc2's Avatar
Re: 4WD High to Low
Originally Posted by diesel_brad View Post
Im sure this
Thanks Brad, saving for crawling under the truck.
Where Brad drilled the grease fitting is were it siezes up.
I heard that the piece is obsolete; so don't break it.
Billy T.
[email protected]
Other vehicles
gnxtc2 is offline
