Idler pulley bolt bushing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-20-2011, 01:48 AM Thread Starter
Needing Carbon Credits
bearing craped out today on the way home. Was able to replace roadside, but the bushing on the bolt got fubared from the heat. Does anyone know where to get the bushing or do i need to visit the dealer for a new bolt.
Muchas gracias.
05 F350 FX4 - Deleted and Exhausted
jmontes is offline
post #2 of 8 (permalink) Old 05-20-2011, 01:29 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: Idler pulley bolt bushing
Is it the LH thread bolt? Sometimes they come with a new tensioner.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #3 of 8 (permalink) Old 05-20-2011, 08:45 PM
Presumably this is for one of the fixed idlers, not the tensioner. But which idler? The ribbed one next to the tensioner, or the smooth one on top?
madpogue is offline
post #4 of 8 (permalink) Old 06-01-2011, 03:52 AM Thread Starter
Correct -The ribbed one. The bolt has a plastic bushing, and the dealer doesn't sell the bolt or the bushing...
jmontes is offline
post #5 of 8 (permalink) Old 06-01-2011, 05:04 PM
Replace it with the SD style tensioner.
Easy swap.
turboaz2 is offline
post #6 of 8 (permalink) Old 06-01-2011, 06:04 PM
Exclamation Re: Idler pulley bolt bushing
Easy swap.
Not worth it, IMHO; you have to buy the SD tensioner and a new belt, its less expensive to buy the OEM or "upgraded" tensioner, and you have to spend your time modding the bracket.
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #7 of 8 (permalink) Old 06-02-2011, 02:22 AM Thread Starter
Why? $150 mod for a $.50 bushing...
jmontes is offline
post #8 of 8 (permalink) Old 06-02-2011, 04:14 AM
Well, the FSM doesn't do a part breakdown on the bolt or bushing/washer. Every listing for the pulley itself (either one) only includes the pulley.
Hmm, doesn't the top smooth one have the same bushing? Best bet might be to remove it, carry it into the local grampa-style hardware store with the gazillion McMaster-Carr bins and the wood floor and the old black dog, and find the closest match.
madpogue is offline
