EBPV Sensor Tube - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-20-2011, 01:31 AM Thread Starter
EBPV Sensor Tube
Installing new engine, and snagged some manifolds from a Med Duty truck because they were in much better shape. The pass side manifold has a plug which is frozen in and stripped. Do I need to go through the trouble of drilling it out?
The truck has a non ebpv ped, is the sensor required, will I get a CEL with out it, or could I just leave it plugged in with out the tube on it?
loudmouth is offline
post #2 of 6 (permalink) Old 05-20-2011, 03:11 AM
Patrick Feeley's Avatar
Re: EBPV Sensor Tube
You could just leave the sensor plugged in without the tube and it shouldn't set the CEL (it will set a code) unless it's a 1997 (and I can't remember, but may only be Cali 1997 trucks). Cheers!
Patrick Feeley is offline
post #3 of 6 (permalink) Old 05-22-2011, 03:42 AM Thread Starter
It's a 97, Federal truck, I guess I better make it work just to be safe!
post #4 of 6 (permalink) Old 05-24-2011, 04:52 PM
OBS Addict
7.3psd97444's Avatar
You can leave it plugged in and not run the ebpv and be just fine.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #5 of 6 (permalink) Old 05-25-2011, 04:06 AM
Cantankerous Old Redneck
Old OutLaw's Avatar
I just got a Dongle, and plugged it in to the harness....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, 3/8" cooling lines, Tru-Cool Max, PML, Bumper Mod, Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".....
Old OutLaw is offline
post #6 of 6 (permalink) Old 05-25-2011, 04:18 AM
96 Ford F-350 PSD
Ford3544's Avatar
If you are not chipping the truck with a programer that does not need the EBPS then you will be fine. If not fix it because it also has to do with your trans shift points and fuel delivery.
96 Ford PSD! Custom intercooler, 01 Aluminum radiator, S&B Intake, 5" exhaust, Stage 2 injectors, Complete stud kit, 3" aluminum intake plenums, Fuel system w/aeromotive pump and regulator, Coolant filter, BTS Trans, Adrenaline HPOP, live tuned DP Tuner, 4" lift, MKW19 wheels and Toyo MTs.
Ford3544 is offline
