Up Pipe Donuts??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-20-2011, 12:23 AM Thread Starter
Up Pipe Donuts???
Ok, So I'm replacing the Up Pipe donuts on the engine I'm getting ready to put in the truck. I did the sbc donuts, crossed over the Napa # to a Felpro 60985. I got the manifolds, and all back on the engine and the inlet is still yet loose after I tighten the flanges as much as I can.
I'm guessing there is no way this can be normal, and there is no way I can afford the bellowed OBS up pipes as much as I would like to.
Any suggestions?
loudmouth is offline
post #2 of 7 (permalink) Old 05-20-2011, 02:02 AM
Needing Carbon Credits
Re: Up Pipe Donuts???
Get the brass donuts from Bean's.
05 F350 FX4 - Deleted and Exhausted
jmontes is offline
post #3 of 7 (permalink) Old 05-20-2011, 02:57 AM
gnxtc2's Avatar
+1
or machine down the clamps.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #4 of 7 (permalink) Old 05-20-2011, 05:40 PM
You could also "reshape" the upipes. What I have done on both my trucks is put a piece of heavy wall pipe in a vise slide the up pipe on it and with a hammer tap lightly to reshape and expand the diameter so the rings slide on with a bit of effort. On the wear marks what I did was to use a sharpie and draw a line around the full circumference of the u pipe. This will aid in maintaining a constant shaping as the hammer will erase the sharpie line. For me this has worked well and have even used the stock exhaust rings. Also as noted you could machine the oring clamps so they are thinner so as to pull them closer to the collector creating a tighter seal.
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #5 of 7 (permalink) Old 05-20-2011, 07:51 PM
Michael's Avatar
I tried the Chevy donuts but they started leaking almost immediately. I went back and shaved about 0.100" from the clamps and used Navistar donuts, been sealed ever since.
95 F350 CC DRW, ISSPRO Performax gauges, Diamond Eye 3x4" DP & 5" exh, MBRP tip, Baby Swamps & tunes, Trans VB mods, Dunrite TC, Lock-Right, Cal-Tracs
99 Silverado race truck
96 F250 RCLB, bone stock
00 Jetta TDI, Kerma Tunes, Der Chimera Stg 3 clutch
73 & 74 Vega race cars, 92 GMC Typhoon, 73 Chevy Blazer with Pontiac 400, 73 Trans-Am 455
Michael is offline
post #6 of 7 (permalink) Old 05-21-2011, 03:36 AM
Yes I tried them too and they leaked right away.....that was on the '96 a number of years ago...was truly a let down and waste of time...
jrc
JCart is offline
post #7 of 7 (permalink) Old 05-22-2011, 01:57 AM Thread Starter
I grabbed a set from the local IH dealer, and it tightened up perfectly!
I guess we'll see how they do. The ones on the truck lasted 290k before they started leaking so maybe we'll be alright!
