Clutch pedal return spring? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-19-2011, 11:18 PM Thread Starter
P.F.F.
smokindiesel2's Avatar
Does anyone make a softer clutch pedal return spring? Or anybody out there know how to make it softer? Thanks for any help.
02 F-250 4X4
96 F-250 4X4
smokindiesel2 is offline
post #2 of 3 (permalink) Old 05-20-2011, 12:32 PM
fordnut's Avatar
Re: Clutch pedal return spring?
the spring is not what your fighting its the clutch itself
anybody want a cheap dana 60 front
fordnut is offline
post #3 of 3 (permalink) Old 05-20-2011, 05:10 PM
You could unhook it and see if it makes a diff. It's kinda tight in there but if you can push the clutch in then using a couple heavy Zap straps while compressed put them on. I just did a ZF swap in and tried it w/o spring and have ended up using it. Not a huge diff for my sop feel. My clutch is a South Bend with the organic/ferric setup for 450 hp single disc. Also used a Dorman aftermarket prebled master/slave system.
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
