ebpv question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-19-2011, 12:53 AM Thread Starter
instagator apperently
Nuttin up's Avatar
Exclamation ebpv question
k i know some of yal have gutted it but my mechanic said that its connected to the computer and moves depending on what the computer tells it to do makin more boost from the turbo and if i remove it i will lose power and not help nothin please help
Nuttin up is offline
post #2 of 7 (permalink) Old 05-19-2011, 12:56 AM
Moderator
PsRumors's Avatar
Re: ebpv question
Find a new mechanic.....the ECM does tell it when to open and close but it does not help make more boost. If anything you will make more power with it gone...if anything.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #3 of 7 (permalink) Old 05-19-2011, 01:45 AM
Re: ebpv question
Run far from that guy.
The ebpv is used to aid the engine in warm up's.....nothing else.
02 f250
countryboyrob is offline
post #4 of 7 (permalink) Old 05-19-2011, 04:12 PM
Drive it like ya stole it
geargrabbin97's Avatar
Re: ebpv question
Hahaha...agreed, find a guy who's worked on powerstrokes and not geos.
97 F250 CCSB: 238/100s, 38r w/1.15 housing, SD conversion, 5" exhaust, Stealth pumps, e-fuel, 910 springs, pushrods, headstuds, intercooled, kevlar/ceramic clutch, tuned by Matt, gauges, 4" lift on 37s. D60 and ZF6 next on the list.
97 F250 ECSB: 3" downpipe, chip tunes by Jody, gauges stock height on 35s. SOLD
geargrabbin97 is offline
post #5 of 7 (permalink) Old 05-19-2011, 06:46 PM
Wink Re: ebpv question
Well you can use it as an exhaust brake, too.
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #6 of 7 (permalink) Old 05-19-2011, 09:56 PM
Re: ebpv question
Tried it and found it to not be worth the hassle. The hole where the rod come's out of the pedistal is a great spot for an oil leak if the valve get's stuck.
For some people it may have worked but for me it didn't work as well as I had read.
02 f250
post #7 of 7 (permalink) Old 05-20-2011, 03:05 PM
Talking Re: ebpv question
I use it like a exhaust brake and in my case it works fine for me, I suppose that the dedicated exhaust brakes MUST work better for sure but MORE way expensive.
