Fuel pump replace - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 05-19-2011, 12:42 AM Thread Starter
Fuel pump replace
I know probably been covered but didn't find it. How do I remove the cover that looks like the Starship enterprise? It say Bosch on it. it's part way under turbo. It has to come off before pump comes out so I can get to banjo bolt, right? Mike
'97 PSD, Cali truck. 2 wheel drive, Ext Cab, Auto. Baby Swamps, T.S. Chip. New glows plugs (ZD11). 273,000 mi. 3in down pipe. Cat & Muff Delete, (Love hearing the Turbo) Gauges, 6637 intake. New UVCH. Black CPS. Turbo next. But which one? In Vancouver, WA
voodoomaker is offline
post #2 of 17 (permalink) Old 05-19-2011, 12:58 AM
Moderator
PsRumors's Avatar
Re: Fuel pump replace
Must be a Cali truck. That piece I don't believe comes off, you have to work around that to get to the banjo bolt.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #3 of 17 (permalink) Old 05-19-2011, 02:51 AM Thread Starter
yes it is a cali truck. What purpose is it? Would it be faster to pull the turbo? and will a regular pump fit and work? Mike
post #4 of 17 (permalink) Old 05-19-2011, 05:28 PM
biggreen96's Avatar
That is for the split shot injectors. Its a pulse dampener. Unless your running single shots I blieve you will still need it.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #5 of 17 (permalink) Old 05-19-2011, 06:27 PM
Exclamation Re: Fuel pump replace
No you dont need to pull the turbo and its faster if you dont, also you can pull the dampener counter clock wise if you want to, but not neccesary. and it could work with a regular pump but Im agree with biggreen96.
I dont have a link in this PC to do that, but if you want, Ill be there in the afternoon, if you want it, let me know.
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #6 of 17 (permalink) Old 05-19-2011, 06:32 PM Thread Starter
Please if you could find it. Thanks. Mike
post #7 of 17 (permalink) Old 05-19-2011, 06:34 PM
Wink Re: Fuel pump replace
I will, later my friend.
post #8 of 17 (permalink) Old 05-19-2011, 06:40 PM
Thumbs up Re: Fuel pump replace
here you are
Cali fuel pump replacement - Ford Truck Enthusiasts Forums
post #9 of 17 (permalink) Old 05-19-2011, 08:14 PM Thread Starter
Exactly what I needed. Thanks! Mike
post #10 of 17 (permalink) Old 05-19-2011, 10:45 PM Thread Starter
Well I got the fuel pump out but the pulsater thing I couldn't get it off. It spins around on it's self where it is put together. Not a big deal cause i did get other pump on. Unless that will leak. Is that possible? Mike
