'97 straight pipe suction noise on startup? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-17-2011, 10:24 PM Thread Starter
never ends
smokin99stroke's Avatar
Me and my buddy cut the cat and muffler out of his '97 single cab yesterday. He was planning to dump it infront of the rear tire but no place around here carries 3.5 inch so he is ordering online. So, for the time being, theres probably about a foot of exhaust after the stock downpipe. He says that when the truck is cold it makes a vacuuming/suction/sucking noise for a few seconds when the truck starts up. He said he had someone look at it and they said it sounded like the vacuum pump?
Not sure if this is coincidence with cutting the exhaust up or what? Just wanted some opinions. I don't think it does it all the time because right after we cut everything out he started it up and it didn't do it then...
The vacuum pump in my super duty went out and the A/C didnt work properly. He said his is working fine.
Also, does anyone know a good site to find 3.5 inch exhaust, connectors, clamps, etc.?
Thanks
'02 F250 CC/SB, 4r100 4x4
'00 F250 EC/SB, ZF6 4x4
E'99 F250 EC/LB, 4r100 2wd
'03 F250 7.3 CC/SB, 4r100 2wd
smokin99stroke is offline
post #2 of 5 (permalink) Old 05-17-2011, 10:43 PM
oil burner
tughill283's Avatar
Re: '97 straight pipe suction noise on startup?
i think your hearing the ebpv
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #3 of 5 (permalink) Old 05-17-2011, 10:54 PM
Yes, its just the epbv if its coming from the exhaust. Nothing to worry about.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 215k miles: FFD 250/200%'s, Swamps IDM, built trans, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube, Homemade e-fuel/intake/exhaust/traction bars, D66, Built and tuned by me
97 ECSB F-250 project truck. Current plans: 7.3, BTS, 250/2's, 468, stock bottom end
JD3020 is offline
post #4 of 5 (permalink) Old 05-18-2011, 12:57 AM
EBPV for sure. I'd say just unplug it B4 the first start up of the day. What i did to mine stright pipe wise was order a 4ft piece of 3.5in pipe from Jegs. I had that next day, cut the flange off the cat, i cut the 90 deg bend off the tailpipe, and took the hanger that was bolted to the cross memeber under my bed off flipped that around and bolted it to the cross memeber under the rear of the cab and welded everything all back together. 25 bucks is all it cost me.
95 F-250 plow/work truck, Meyer 7.5 ft plow, lift gate, cat delete, straight pipe, fact. no A/C, CCV Mod, Tymar intake, Diesel Site trans filter, SD tensioner
bigblock_ford1969 is offline
post #5 of 5 (permalink) Old 05-19-2011, 01:20 AM
kbmkviii's Avatar
96- PIS 350 200s. 76mm Billett GT4202R. Big Oil. Twin E-Fuel.
BTS. Sump. 140v IDM. Melling. Fluidamper. H11. VS. PR.
Auto Meter- Boost, Pyro, HPOP, Trans, Fuel.
HPOP/coolant/trans filters.
6.0 I/C and Trans cooler.
2012 SRT8 300 6.4
kbmkviii is offline
