Rear End Problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-17-2011, 02:32 AM Thread Starter
97BigRed
BigRed.Sept.97's Avatar
Rear End Problems
Here's one that's been stumping me for a while now. I can't seem to keep rear tires on my truck. (Definitely not from burn outs) The truck simply chews the rear tires off. I have never gotten more than 18k out of any size, shape, or make of tire since the factory tires. I have changed the rear end fluid twice, added friction modifier, etc. Fluids look fine, nice and clean, not burnt, and gears look brand new. No welds, etc... Any ideas? Has anyone else had this problem? I would love to get some more mileage out of a set of tires!! Thanks for any help!
97 F350 4x4. 3" DP. 4" exhaust. Cold Air Intake. Luk Clutch. Auto Meter Gauges. Sniper Chip.
BigRed.Sept.97 is offline
post #2 of 10 (permalink) Old 05-17-2011, 02:53 AM
rolsmojave3's Avatar
Re: Rear End Problems
Do they wear evenly? Do you pull anything? Rotate much?
97' F-350 7.3 5 speed, 160cc Rosewoods, 315/75r16s 16x10 MT fakelocks
96' F-350 7.5 5 speed, cali truck, 315/75r16s on Alcoas
02 Ranger FX4
79 "F350" mud truck, 18.5/44-16.5s
rolsmojave3 is offline
post #3 of 10 (permalink) Old 05-17-2011, 03:37 AM
Fixing Broken Stuff
toolmangary's Avatar
I have never even herd of that before. I have got maybe 60k out of tires before. IDK ????
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #4 of 10 (permalink) Old 05-17-2011, 03:48 AM
Dtm030's Avatar
I had rear end problems about a year ago. Went to the doctor and showed him and with a little time with the knife I was fixed. The healing wasn't fun as it could have problems but it's all good now. Jokes.
Have you had a wheel alignment to check? That is the weirdest problem? Do they wear evenly?
08 F250 CC/SB Spartan Tuned - sold
I say take her out for some drinks, get her in the mood and ride it like a rented mule... might be the last time
Dtm030 is offline
post #5 of 10 (permalink) Old 05-17-2011, 03:49 AM
Dtm030's Avatar
Also what pressures are you running?
Dtm030 is offline
post #6 of 10 (permalink) Old 05-18-2011, 03:39 PM
Zrock's Avatar
Have you checked to make sure your rear axle is not moving. I have seen it severall times were teh rear axle has walked breaking the spring center pin and staying in that position for years before anyone noticed. All looked good and tight untill we pulled apart... Get a 4 wheel alignment
Zrock is offline
post #7 of 10 (permalink) Old 05-19-2011, 02:52 PM Thread Starter
97BigRed
Hey guys thanks for the replies! To answer some questions I always run my tires at the recommended max pressures. I am running 285/75/R16's at 65 psi currently. I do tow, I work in excavation so I have a trailer on with equipment relatively often. I have had it aligned but it has been some years, so that is a good idea to check, thanks! Also, I check my truck over often and have never noticed any pins being broken or my rear axle moving, but I will be sure and double check that, good thing to watch for. Also, a tid bit i forgot to mention, on pavement when I turn tight say in a parking lot, the rear end growls and has a subtle vibration you can feel/hear at low speeds... Thanks for the ideas !
post #8 of 10 (permalink) Old 05-19-2011, 03:08 PM
Zrock's Avatar
rear end could be going south on you locking up on turns... Or you have some sort of limited slip in the back?
When we fount the broken center pins we did not know until we pulled it apart. everything looked good and tight and no movement by hand
Zrock is offline
post #9 of 10 (permalink) Old 05-19-2011, 09:08 PM Thread Starter
97BigRed
ZRock, I'll be sure to check those pins. That has me wondering now. And I'm afraid of what you're saying about the rear end going south... it seems as though it gets worse the older / more miles the truck gets. It does have a limited slip rear end in it. Anybody have ideas or good places to look at rear end parts ie factory limited slip rebuild kits or elockers?
post #10 of 10 (permalink) Old 05-20-2011, 04:28 PM
Cratos's Avatar
have you checked you spring bushings? if there shot it wount track.
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
