water injector location - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-16-2011, 10:54 PM Thread Starter
hit n miss
Peroni's Avatar
Guys where is the preferred place to put the injector nozzle with a water/meth setup?
I thought of locating it in the spider, right where the big tapped hole is at the Y. I don't know if this is too close to the intake. I also thought a bit further up in the spider, right behind the boot for the cold side pipe.
I wanted to avoid having to weld a bung on the cold pipe as I don't have a working welder here. Got plenty of equipment to drill and tap a hole in the alum spider though.
Found a couple threads on the subject but there was no solid consensus of what is acceptable.
97 Green F-350 XLT 7.3L PSD 4x4 CC LB BTS E40D Manual Hubs 4.10 36000 miles when purchased 4/1/06. Mods - ISSPRO Performax gauges, Tymar intake, Tymar 3x4 DP to 4" ss exhaust, electric fuel, CCV mod, 6.0 fan, tru-cool 4739, Swamps 175/30% injectors, stage I Stealth pump, LASB turbo, Spearco 6.0 cac, live tuned 442hp/860tq.
Peroni is offline
post #2 of 3 (permalink) Old 05-17-2011, 02:38 PM
OBS Addict
7.3psd97444's Avatar
Re: water injector location
I think you would be fine putting it in your intake Y. I'm guessing it's going on your sig truck(nice setup btw). Do you even need water? JW.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #3 of 3 (permalink) Old 05-19-2011, 01:29 AM
kbmkviii's Avatar
water/meth have great affects on even a completely stock motor. i nocited a huge difference. and for the location the middle of the Y is fine.
96- PIS 350 200s. 76mm Billett GT4202R. Big Oil. Twin E-Fuel.
BTS. Sump. 140v IDM. Melling. Fluidamper. H11. VS. PR.
Auto Meter- Boost, Pyro, HPOP, Trans, Fuel.
HPOP/coolant/trans filters.
6.0 I/C and Trans cooler.
2012 SRT8 300 6.4
kbmkviii is offline
