tail lights and dash - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 05-16-2011, 06:12 AM Thread Starter
Last night when I went to go somewhere my dash lights would not come on. I got out and also noticed my tail lights were out to. Blinkers, reverse, and brake lights all work. I found 2 blown fuses and changed them but still no change. What else should I look at? Thanks.
97 F250 PS is offline
post #2 of 9 (permalink) Old 05-16-2011, 06:14 AM
TBarrsTruck's Avatar
Re: tail lights and dash
Did they blow again? Which ones where they?
'97 4x4 ECLB: SD IC, TW 4 pos, afe, 3-4" w/areoturbine, 4 gauge, DIY stage 1s, GTP38R, cust E-fuel, E-brake, stage3 CM meth, 439hp still trying for 600. cust stereo, highamp alt, cust paint
'78 F-150 RCLB: 460 swap, 3" lift, 33's,Trussed 9" w/ chrome-moly shafts, cust stereo, locked front/rear. My first love! EFI & Turbo coming soon...
TBarrsTruck is offline
post #3 of 9 (permalink) Old 05-16-2011, 05:23 PM Thread Starter
They didnt blow again. I change #13 in the cab. And I also changed one under the hood which was a small fuse 25amp.
post #4 of 9 (permalink) Old 05-16-2011, 05:59 PM
Bugman's Avatar
Have you hooked up a trailer latley? Also I would start to look for a loose wire under the truck, also took at the trailer wire harness.
The tail lights and dash are usually on the same fuse to let you know that the tail lights are out when you don't have any dash lights. If the one that you changed under the hood was the #4 fuse it is for the Trailer Marker Lamps Relay, Trailer Backup Lamps Relay
Bugman is offline
post #5 of 9 (permalink) Old 05-16-2011, 07:34 PM Thread Starter
I bought the truck about a month ago and the trailer wire harness looks like a mess. I haven't hooked up a trailer yet . Should I just rewire the harness?
post #6 of 9 (permalink) Old 05-17-2011, 02:00 AM
Check all connections at rear of truck for corrosion. Check license plate light sockets and see if they are rusted out. Pull trailer plug apart and look for corrosion. Whenever I had an issue similar to yours, it was always at the rear of the truck. Good luck.
97F250, EC LB 4x4 7.3 5sp 3:55,Donaldson Intake, Running W75/12.5/12.5 as of 2/20/12
Mudbrother is offline
post #7 of 9 (permalink) Old 05-17-2011, 02:04 AM
97BigRed
BigRed.Sept.97's Avatar
I agree with the consensus. I had a problem when I turned my turn signal on either direction, all three of my tail lamps flashed. Corrosion was shorting all of my trailer hook up connections together under the rear bumper.
97 F350 4x4. 3" DP. 4" exhaust. Cold Air Intake. Luk Clutch. Auto Meter Gauges. Sniper Chip.
BigRed.Sept.97 is offline
post #8 of 9 (permalink) Old 05-17-2011, 03:34 AM
Check fuse #4 in the interior fuse box. It's the one in the far opposite corner of the box from the turn signal can.
madpogue is offline
post #9 of 9 (permalink) Old 05-17-2011, 03:43 AM Thread Starter
Fixed it. Fuse #4 was melting do to a loose wire from the trailer harness hitting the frame. Thanks everybody for all the help.
