95 F-250 7.3 PCM Reflash - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-16-2011, 01:00 AM Thread Starter
How can I get the PCM reflashed to 1996 coverage with the truck inop. Its not running and I wanted to purchase an AE code reader to diagnose the No Start. They said the PCM has to be flashed to 1996 coverage?
prerunner007 is offline
post #2 of 4 (permalink) Old 05-16-2011, 01:11 AM
Re: 95 F-250 7.3 PCM Reflash
Your local ford dealer should be able to do it, or contact php(powerhungry performance)
02 f250
countryboyrob is offline
post #3 of 4 (permalink) Old 05-17-2011, 04:23 AM
blageurt's Avatar
Thats funny because my other PCM which is a 95 code TEE5 works perfect with my scanner(AutoTap) which is similar to AE ...maybe they think that your PCM is not OBDII which of course it is ....You could always use a Snap-on MT2500 to diagnose it .
I don't see why the AE would not work with yours...
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #4 of 4 (permalink) Old 05-17-2011, 03:46 PM
AZStang's Avatar
I sent mine to Jody and he flashed it to TDE1.
Customer Supplied PCM Flash Stock or Optional Performance Flash - PCM Flash - Tuning - Ford Powerstroke 7.3L
Shawn
96 Roll-A-Long F-350 4x4 Crew: 135,000 miles, built E4OD, 1.0 exhaust housing, 3"x4" down pipe, 4" exhaust, Navistar water pump, SKY RSK with SD springs.
AZStang is offline
