help! injectors?pump? rings? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 05-15-2011, 04:23 AM Thread Starter
obs96
96 f350 PowerStroke cc 4wd 375000+ mi.
i rev up about 2-2500 rpm and it blows lots of blue smoke n acts like it's running out of fuel.
i need help
icarus is offline
post #2 of 12 (permalink) Old 05-15-2011, 05:41 PM
blageurt's Avatar
Re: help! injectors?pump? rings?
any codes ?
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #3 of 12 (permalink) Old 05-15-2011, 06:24 PM Thread Starter
obs96
I didn't check for codes. I don't have anything to do check with. I just got the truck last summer and ran it for 20,000+ mi.
I will add that the truck wont start below 75 degrees or there abouts. (I keep it plugged in all the time)Sometimes when I start it it does several seconds of hard lopes, at idle. But then instantly smoothes out and runs great but seems to lack power that I expected. Or at least till now.
I start the truck, take off, all ok, a few miles down the road it starts running rough. Like it's running out of fuel. Rough idle, no power, rev up an strong fuel smell with intense blue smoke.
I was thinking bad injectors,, but I don't know much. Looking for you guys advice
icarus is offline
post #4 of 12 (permalink) Old 05-15-2011, 06:52 PM
95powersmoker's Avatar
I would do a compression test with that many miles...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #5 of 12 (permalink) Old 05-15-2011, 07:51 PM
blageurt's Avatar
It's hardley ever the injectors ... I would check your fuel pressure and smell the oil cap....Pressure should be over 50 psi at idle and If you smell burn't plastic when you nose the cap you have burn't UVC harnessess or Engine harness clips or both ..... so you need to take VC 's off to check that ...
blageurt is offline
post #6 of 12 (permalink) Old 05-15-2011, 10:51 PM Thread Starter
obs96
I don't mean any disrespect, but what's UVC? (under valve cover?
icarus is offline
post #7 of 12 (permalink) Old 05-15-2011, 10:55 PM
He was mentioning the harnesses under the valve covers.. They supply power to your injectors and glow plugs...
James
post #8 of 12 (permalink) Old 05-16-2011, 03:58 AM
OBS Addict
7.3psd97444's Avatar
^ what they said. Also if you smell strong fuel obviously check for fuel leaks. Specially in the valley near the pump.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #9 of 12 (permalink) Old 05-16-2011, 01:54 PM Thread Starter
obs96
I think I'm misunderstood, the strong fuel smell is in the exhaust. There's nothing leaking anywhere.
icarus is offline
post #10 of 12 (permalink) Old 05-16-2011, 02:58 PM
OBS Addict
Ok just making sure as that could mean bad fuel pump if it's leaking.
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
