Fuel line leak. Could this be the fix? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-15-2011, 03:07 AM Thread Starter
Can a 1 ton do a wheelie?
purple_heart_350's Avatar
I replace my fuel pump a few weeks ago and ever since I noticed it was leaking. The fuel line that goes to the back of the heads is leaking on the driver side the o-ring is jacked up and I just want to make sure that this is the o-ring or whatever it is, is what I need?
Replacement O-rings for Ford Diesel Engines
'95 F350
IDM mod, FPR shim, 3 1/2" DP and CAT delete, aFe Big Boost, Quad pod-autometer Z seires gauges, 4" straight pipe exhuast, TS 6 position chip from KT performance
"Would it kill you to buy american" Clint Eastwood
purple_heart_350 is offline
post #2 of 3 (permalink) Old 05-15-2011, 04:20 AM
Patrick Feeley's Avatar
Re: Fuel line leak. Could this be the fix?
Those look correct (at least they look the same as the ones I used). Cheers!
Patrick Feeley is offline
post #3 of 3 (permalink) Old 05-15-2011, 08:37 AM
Moderator
PsRumors's Avatar
Those are they
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
