Stripped oil pressure sensor threads... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 05-14-2011, 01:05 AM Thread Starter
Long story short, I pulled the oil pressure sensor off the top of the HPOP reservoir and in a rush, stripped the threads putting it back on. What is the fix for this? A new HPOP reservoir?
-John-
1996 F-250 Ext Cab Long Bed 4x4 w/ a few mods
jmsmith76 is offline
post #2 of 11 (permalink) Old 05-14-2011, 02:00 AM
<-Friends bike
Re: Stripped oil pressure sensor threads...
either way you will need to pull the cover off the res , you may be able to run a tap in to clean the threads .. Don't quote me on it , but IIRC the threads are 1/8 pipe ...
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
ActionRick is offline
post #3 of 11 (permalink) Old 05-14-2011, 02:10 AM Thread Starter
well i got a tap and die set so i'll keep my fingers crossed that it'll work. what is the procedure for removing the cover? just pump oil out and pull the bolts up top? or is it more involved?
-John-
post #4 of 11 (permalink) Old 05-14-2011, 02:44 AM
<-Friends bike
That should do it ...
Rick....
post #5 of 11 (permalink) Old 05-14-2011, 03:10 AM
Bugman's Avatar
Worse case would be that you will need to pull it off, drill and tap it for a bushing that would reduce it down to the 1/8" that you need.
Bugman is online now
post #6 of 11 (permalink) Old 05-14-2011, 05:12 AM Thread Starter
Thanks, in all the stuff i've done to my truck, i've yet to disassemble any part of the HPOP (other than the IPR), so i thought it might have been an ordeal, but glad to hear it should be fairly straight forward. I plan to upgrade to an aftermarket pump someday to support my injectors...
-John-
post #7 of 11 (permalink) Old 05-14-2011, 03:15 PM
Heli-coil is a threaded insert that will work. Comes in a kit you drill srripped hole oversize tap and screw in the heli-coil and the inside of the coil is the original size that you stripped. Iirc they are ss and strong so you will not have to worry bout cross threading again, they work awesome.
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #8 of 11 (permalink) Old 05-14-2011, 03:38 PM
Bugman's Avatar
A helicoil would work but I have never seen one for a pipe thread.
post #9 of 11 (permalink) Old 05-14-2011, 03:57 PM
Patrick Feeley's Avatar
I've never seen one for a pipe thread either. Remember that older PSDs had the 1/8 NPT switches, while the later ones had the straight thread o-ring'ed switched (helicoil would work for those). Cheers!
Patrick Feeley is offline
post #10 of 11 (permalink) Old 05-14-2011, 03:58 PM
I stand corrected Bugman think you're right on that. Guess the other option would be to drill, thread oversize and put in reducer to 1/8" npt.
jrc
JCart is offline
