97 Automatic Transmission Leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-13-2011, 04:01 AM Thread Starter
mjonesjr's Avatar
My transmission is leaking fluid out of the inspection cover between the engine and transmission. It only has 111,xxx miles on it.
Any ideas what that might be? I was thinking it was the front seal, but have no clue. I haven't had a chance to pull the cover yet as it just started leaking.
Any help would be great.
1997 F-250HD Extended Cab 4x4 7.3 Powerstroke
3" Down Pipe to 4" Exhaust (Stainless) ~ Tymar Intake ~ TS 6 Position Chip ~ HPOP Cross Over Line ~ Regulated Return ~ E-Fuel System ~ Intercooled ~ CCV Mod ~ Dana 60 Swap
mjonesjr is offline
post #2 of 3 (permalink) Old 05-13-2011, 04:45 AM
rusty9cab's Avatar
Re: 97 Automatic Transmission Leak
Does it leak all the time or just when it gets hot? Mine leaks past the front seal when it gets above 175 degrees. There is an updated seal that is made of Viton. I had my tranny out last year and am kicking myself for not replacing it.
1997 F-350, XLT supercab dually, auto, tymar intake, ISSPRO gauges, tymar downpipe and "off road" pipe, DP tunes...to be continued
rusty9cab is offline
post #3 of 3 (permalink) Old 05-16-2011, 03:57 AM Thread Starter
mjonesjr's Avatar
It doesn't leak when it is normal driving, just when it gets up around 180*.
I am adding a 26,000# GVW cooler to my transmission lines this week.
mjonesjr is offline
