Hesitation with Chip again :( - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 05-13-2011, 02:47 AM Thread Starter
96Powerstrokin's Avatar
I have a 96 250 Powerstroke.
Dp tuner bought off a friend ran fine in his 95 when we took it out.
In my truck it gets a hesitation if I floor it. For example if I push the pedal to the floor it bogs down clears out and goes and it will do the same thing if you try to pass someone on the interstate. However if you ease into it the truck runs fine up to about 3/4 throttle. It sounds like the truck isnt getting enough fuel.
I thought it was fuel pressure as my pump was leaking. Replaced the pump and the truck still does it. My HPOP is full and I have no oils or diesel leaks that I know of. I am stumped.
2008 F250 CCSB 4x4, 101K Stock
2004 F350 CCLB FX4, 6.0, 4x4, 2.5 Leveling Kit, 305s, SCT Tuner, 260k, Built Trans with Triple Disc Billet Converter. - SOLD
1996 F250 SCLB 4x4, E40D, Powerstroke, DIY Intake, EBPV Delete, DP Tuner, 4 In Lift, 342k - SOLD
96Powerstrokin is offline
post #2 of 12 (permalink) Old 05-13-2011, 03:34 AM Thread Starter
Re: Hesitation with Chip again :(
The truck runs perfectly fine and can be floored when its cold like the first start of the morning but after that it cant be
post #3 of 12 (permalink) Old 05-13-2011, 04:13 AM
OBS Addict
7.3psd97444's Avatar
Sounds like a case of the "stock injectors and HPOP can't keep up disease."
Does it do it on all the power levels?
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #4 of 12 (permalink) Old 05-13-2011, 04:20 AM
95powersmoker's Avatar
IMO, the best thing you could do is get the truck on a scanner and get some live data...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #5 of 12 (permalink) Old 05-13-2011, 04:22 AM Thread Starter
If that was the case why would it run perfectly fine when its cold?
post #6 of 12 (permalink) Old 05-13-2011, 04:23 AM Thread Starter
Every shop around here wont touch the diesel, i am trying to find someone with ae.
post #7 of 12 (permalink) Old 05-13-2011, 04:27 AM
OBS Addict
Yeah that's confusing. Get it hooked up to a scanner.
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
post #8 of 12 (permalink) Old 05-13-2011, 04:34 AM Thread Starter
possibly a cps issue? I was thinking of unplugging the ipr and see if it changes
post #9 of 12 (permalink) Old 05-13-2011, 04:52 AM
You mean unplug the ICP sensor? I doubt its a CPS issue...
James
post #10 of 12 (permalink) Old 05-13-2011, 05:09 AM Thread Starter
yea thats wat i meant
