Steering has me stumped - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 05-10-2011, 11:32 PM Thread Starter
REZ
STILLKICKIN_F250's Avatar
After work my steering was perfectly fine for about 10 miles. Of course as i came up to a busy traffic circle my steering got extremely stiff and i had to man handle it to barely make it around the circle. once clear of the circle I tried turning right into a parking lot but the wheel turned just enough to coast me towards the shoulder. I rubbed the curb and heard a pop/ clank and suddenly had partial steering. i managed to get into a parking lot.
I checked...
power steering fluid, lines, and hoses. all good. ball joints all good. tie rods axles and any steering linkage. all good.
After me turning the wheel back and forth 28374687236 times in the lot i took it around the lot and everything seemed ok. i limped it most of the way home and then it started to pull and stick when making right turns or going around bends to the right. i finally managed to get the truck home and im stumped
1996 F-250 7.3LTR 4X4 AUTO SCLB - INTAKE, EXHAUST, CHIP
STILLKICKIN_F250 is offline
post #2 of 12 (permalink) Old 05-11-2011, 12:32 AM
Built not Bought
1990 Scorpion's Avatar
Re: Steering has me stumped
Do you have any power steering leaks? What about noises kinda sounds like your steering box grendaded.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #3 of 12 (permalink) Old 05-11-2011, 12:45 AM Thread Starter
REZ
No leaks. Only sound was the pop/clank when I bounced off the curb. Before and after that so unusuall sounds
post #4 of 12 (permalink) Old 05-11-2011, 12:48 AM Thread Starter
REZ
How big of a pita is the steering box to change? Are there any ways to test it and be sure?
post #5 of 12 (permalink) Old 05-11-2011, 02:15 AM
ford2go's Avatar
Look at your u joints on the front axle.I had a truck the joints looked good but after pulling the axle out found the joint was seized up.It was making the truck hard to turn and would not return very good.
ford2go is offline
post #6 of 12 (permalink) Old 05-11-2011, 05:08 AM
Drinkin like a fish...
d-selpowereddiebauer's Avatar
Could be that too...my money is on the gearbox tho. Good luck.
d-selpowereddiebauer is offline
post #7 of 12 (permalink) Old 05-11-2011, 06:01 AM Thread Starter
REZ
Thanks. I really think Im going to need it.
How much trouble is the gearbox to replace?
post #8 of 12 (permalink) Old 05-11-2011, 06:01 AM
biggreen96's Avatar
Gearboxis not that hard to change out. Dissconect shaftfrom box remove two lines and steering linkage,then remove the three bolts on the frame and box will drop out.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #9 of 12 (permalink) Old 05-11-2011, 06:03 AM Thread Starter
REZ
Sounds easy enough. Thanks
post #10 of 12 (permalink) Old 05-11-2011, 07:02 AM
I know nothing...
joedaddy's Avatar
Brad claims the F350's all the way down to the Rangers are the same box if you're going hunting?
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
