Rotary Ignition Switch - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 05-10-2011, 03:28 AM Thread Starter
Roll on
redpower's Avatar
Tonight something happened to my ignition switch. It seems to be stuck in the "run" position. I can turn the switch to "off", "acc", and when I hit "start" the starter turns. It feels like there is no resistance when you turn it. Switch bad? Something in the column? What parts do I need and how bad is this to change?
1997 F-350 DRW
1995 F250
redpower is offline
post #2 of 20 (permalink) Old 05-10-2011, 02:33 PM
zilla68's Avatar
Re: Rotary Ignition Switch
I hope you figure it out, mine is doing something very similar. I think its a combo of the key switch and "the rack" I believe, but I've been putting tearing mine apart now for a while, lol
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #3 of 20 (permalink) Old 05-11-2011, 03:28 AM Thread Starter
Roll on
redpower's Avatar
Well.... I took apart the column, or more like I took the bottom cover off and found the rotary switch comes out real easy. I am hoping that is the broken piece. Still any input from anyone would be great.
1997 F-350 DRW
1995 F250
redpower is offline
post #4 of 20 (permalink) Old 05-11-2011, 10:13 AM
Drinkin like a fish...
d-selpowereddiebauer's Avatar
Fix it before you get it to the "OFF" position. If it gets locked in that position, ya have to go thru the PITA of drillin the pin...if I remember correctly, anyway. Consult a Haynes or Chilton manual for directions on the swap-out.
d-selpowereddiebauer is offline
post #5 of 20 (permalink) Old 05-12-2011, 03:32 AM Thread Starter
Roll on
redpower's Avatar
My problem is deeper than the key switch. I guess I will start to take the column apart, as soon as I can find a steering wheel puller. Anyone ever taken one apart? My Haynes manual doesn't have an exploded view either. Anyone have one of those?
1997 F-350 DRW
1995 F250
redpower is offline
post #6 of 20 (permalink) Old 05-12-2011, 12:51 PM
Not sure what the issue is in terms of fixing it. I just did a full E4OD to ZF-5 swap including the columns. To get the steering wheel off (as I wanted to switch those too). What I did was loosen the steering wheel nut so where ample threads between nut and wheel. Now I grabbed the wheel and pulled with even pressure top and bottom. To a bit of work but was able to get it off. When you remove the nut look to the end of the steering shaft as there should be a small yellow dot or punch mark on the end of the shaft face. To re-align wheel and shaft punch mark should be in 12:00 o'clock position.
You might just need to lude all moving parts if sticking tumbler. I cleaned the contacts on the underside of the wheel and reapplied dialectric grease to contacts. Also used white lithium grease on other moving parts. Just take your time.
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #7 of 20 (permalink) Old 05-13-2011, 03:02 AM Thread Starter
Roll on
redpower's Avatar
So I took more of the column apart and discovered the rod ( I think thats what you call it. Long plastic piece runing through the center of the column) was broke. I have no clue how you get it out, or if I can get a new one.
My mechanic tells me they never break in the OBS style trucks. That scares me a little that maybe more is wrong.
1997 F-350 DRW
1995 F250
redpower is offline
post #8 of 20 (permalink) Old 05-13-2011, 03:05 AM
zilla68's Avatar
they are available new, go to partsguyed.com or one of the ford dealership sponsors and they can get it for you. partsguyed sent me a blow up and told me what I would need, aparantley they do break, he knew what it was right off the bat.
Chris
Moore, Oklahoma
6637 tymar
3:55 gears
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #9 of 20 (permalink) Old 05-13-2011, 03:56 AM
Built not Bought
1990 Scorpion's Avatar
That "rod" piece does break in the OBS's, mine broke a couple months back. Parts break after extended life and use.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #10 of 20 (permalink) Old 05-13-2011, 04:17 AM Thread Starter
Roll on
redpower's Avatar
Did you fix it yourself?
1997 F-350 DRW
1995 F250
redpower is offline
