water leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-09-2011, 07:32 PM Thread Starter
water leak
there is water dripping from my very bottom pully do yall think ints the waterpump or a hose
93 idi 2WD is offline
post #2 of 5 (permalink) Old 05-09-2011, 07:32 PM Thread Starter
Re: water leak
its on my 97
post #3 of 5 (permalink) Old 05-09-2011, 07:38 PM
blageurt's Avatar
Re: water leak
On my truck I thought it was the pump....thankfully it was only the thermostat...some idiot siliconed the o-ring instead of installing the new design thermostat which comes with the o-ring integrated with it... I would start there...
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #4 of 5 (permalink) Old 05-10-2011, 05:15 PM
96P_Stroke4x4's Avatar
Re: water leak
99% of the time it is dripping from the weephole behind the waterpump pulley. you cant see the weephole from under the truck, but if the bottom of the waterpump is stained behind the waterpump pulley, its time for a new waterpump.
'96 F-250 XLT,x-cab,4x4,BTS,363k,dana60,Swamps175/173s,Dieselsite Adrenaline HPOP,CPR Fuel system,rear discs,4" dp to 6" exhaust,twin 6" stacks,Tymar, Boost Pyro Tranny and white-faced gauges,I/C,onboard air,HX mod,TW 6-position chip
96P_Stroke4x4 is offline
post #5 of 5 (permalink) Old 05-10-2011, 05:20 PM
psdguy97
psdguy08's Avatar
Re: water leak
Water pump time...
95 F-250 ECLB
6637 air intake, 3 inch dp to 4 inch exhaust, EBPV delete, ccv mod, glowshift gauges ( fuel pressure, boost, trans temp, pyrometer ) Dp tuner ( no start, stock, 80hp econo, 60hp tow)
Cobra 29 classic w/nightwatch, Wilson 1000 magnet mount, weather guard backrack, code 3 lightbar.
psdguy08 is offline
