Belt Broke - No Brakes? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 05-09-2011, 02:51 PM Thread Starter
V97F350's Avatar
Pouring rain here this morning, I just get in my development and I hear a noise and see lights light up on my dash, I shut it down immediately, get out in this down pour and find my serpentine belt is off maybe broken, etc. I didn't spend any extra time looking at it cause it was ah raining...raining hard that is
Turned around and parked it back in my driveway, went in the house to change and dry off, then drove my brother's mini van to work.
Question is why did I not have normal brakes? I could stop but I had no power brakes.
Oh and turning this beast is not the easiest without power steering.
Its a good start to the week for me...
'97 F-350 4x4 Crew Long Box Auto 4.10 6637 Air Filter, 3" Downpipe, Rebuilt E4OD
V97F350 is offline
post #2 of 11 (permalink) Old 05-09-2011, 03:04 PM
mandkole's Avatar
Re: Belt Broke - No Brakes?
The belt drives a vacuum pump for the brakes. No pump, no power assist. Look at your accessories, pulleys, belt tensioner closely as belts don't usually just fall off or break.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #3 of 11 (permalink) Old 05-09-2011, 03:05 PM
Moderator
PsRumors's Avatar
Because you need vacuum for your brakes to work. When the belt broke the vacuum pump stopped along with all of the other accessories.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #4 of 11 (permalink) Old 05-09-2011, 03:06 PM
Moderator
PsRumors's Avatar
Unless they are old....
PsRumors is offline
post #5 of 11 (permalink) Old 05-09-2011, 03:07 PM
SIZE MATTERS
7.3-StRoKeR's Avatar
You had no brakes because our trucks do not make vacuum. They require a vacuum pump that is turned by the serpentine belt located directly above the power steering pump. So when the belt broke the vacuum pump wasnt making and vacuum. No vacuum no brakes.
Hope this cleared it up for ya.
- 96 F250 XCSB PSD Auto 255,000 mi -
- 96 F350 CCLB PSD 5spd 98,000 mi-
3" Body lift and Leveling Kit
285/75-16 Federal Couriga Mt
3" DP to 4" to 8" Cat Stack
TS 6 Position Chip
GlowShift - EGT, Boost and Trans
CCV Mod
FRP Shim
EBPV Brake
AirLift Bags
To Come.........
4X4 Conversion, Stage 1's, E-Fuel, Adrenaline HPOP, Intercooler
7.3-StRoKeR is offline
post #6 of 11 (permalink) Old 05-09-2011, 03:48 PM Thread Starter
V97F350's Avatar
That makes sense - that there is a vacuum pump.
I know these serpentine belts don't normally just break - so hopefully its just an idler pulley or something simple. I just started driving my truck again, tranny died on January 13th, and I finally had enough $$$ to get it fixed and back on the road on April 29th
V97F350 is offline
post #7 of 11 (permalink) Old 05-09-2011, 09:24 PM Thread Starter
V97F350's Avatar
Thanks for the replies, it been a long day at work waiting to get home to see what is wrong.....just a couple more hours. Then I'll go to my daughter's High School Fastpitch Softball Game, then home.
V97F350 is offline
post #8 of 11 (permalink) Old 05-09-2011, 10:42 PM
gnxtc2's Avatar
Or the vacuum pump seized up. Don't ask me how I know.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #9 of 11 (permalink) Old 05-10-2011, 02:09 AM
On my 93 there was a recall for the tension pulley, it would lock up and everything stopped working.
Tombo is offline
post #10 of 11 (permalink) Old 05-10-2011, 02:22 AM
farmall16's Avatar
I had a belt break while on was on vacation one time. My alternator seized up.
1997 F-250 CCSB 4x2 7.3 Auto. 4x4 conversion in process.
1995 F-250 ECLB 4x4 7.3 Auto. In pieces.
farmall16 is offline
