major oil consumption!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-08-2011, 10:57 PM Thread Starter
Dieselnut7.3's Avatar
ok my truck just recently after pulling a car on a trailer started burning oil bretty bad. it went through 6 qts in a week. my buddy who used to work at international said it may be my injector o-rings or the internals of the injectors thats causeing it to burn it. but i just put in used injectors before winter so i would think the o-rings would be good since i replaced them with new ones. also i have the 10k resistor mod on my truck and when i take tghe resistor out now the truck lopes real bad and has no power. so it pretty much wont run without the resistor in now. i have it set up for my old set of injectors to get rebuilt by jim at the end of the month but i just want to be sure (or as sure as i can be) that it is the injectors. this truck doesnt leak so its not leaking any out.
thanks!
2003 F-250 6.0L 102kmi all stock except 4in cat back exhaust
(sold)1995 F-350 Dually 5sp 310k and counting. cold air intake, ts 6 position chip, Stage 1 injectors, 3in DP to 5in dual stacks.,
Dieselnut7.3 is offline
post #2 of 7 (permalink) Old 05-08-2011, 11:00 PM
swamp_ratt's Avatar
Re: major oil consumption!!
Possible it could be orings. Check the fuel bowl. If the fuel in there is black then you need orings
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
post #3 of 7 (permalink) Old 05-08-2011, 11:02 PM Thread Starter
yea the only problem about checking the fuel bowl is that i run waste motor oil and transmission fluid with fuel so the filter is already colored black lol
post #4 of 7 (permalink) Old 05-08-2011, 11:11 PM
swamp_ratt's Avatar
Haha. Well that rules that out
post #5 of 7 (permalink) Old 05-08-2011, 11:16 PM
neverkickn's Avatar
Does it smoke bad?
Using that much oil it has to be smoking. Do you have oil in the ehxaust? could be the turbo.
01 f250 scsb Work Truck
neverkickn is offline
post #6 of 7 (permalink) Old 05-08-2011, 11:20 PM
greenbeast's Avatar
The resistor mod is upping the ICP pressure, that is why when you take it off it lopes. You need new injector o-rings.
greenbeast is offline
post #7 of 7 (permalink) Old 05-09-2011, 04:40 AM
OBS Addict
7.3psd97444's Avatar
I dint like the resistor mods simply because of this. To risky. Should just stick to tuning IMO. Good luck.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
