trans swap questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 05-08-2011, 03:33 AM Thread Starter
swamp_ratt's Avatar
Got a guy has a cclb 94 turbo idi wants to trade me his e40d for my zf5. Of course all related components will be traded. Is his e40d the same as the one behind a psd? Also can him and i trade gauge clusters and columns? I know i would need an auto pcm. How about the trans harnesses? Will the manual trans harness hook up to his truck and will his auto harness hook to my truck?
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
post #2 of 16 (permalink) Old 05-08-2011, 03:57 AM
blageurt's Avatar
Re: trans swap questions
Guages and clusters at least the tach is different the rest I don't know ...As far as I know, the IDI trans is different..I know for a fact that the TC is different... IDI only has 4 bolts on TC....PSD has 6 ..... Internally I have no idea but I doubt it...the IDI also has a PCM to control the trans ...so you would need a PCM from an Auto truck similar to yours for the trans to work...
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #3 of 16 (permalink) Old 05-08-2011, 04:09 AM Thread Starter
swamp_ratt's Avatar
Im not worried about on my end right now as my truck is in a million pieces. I just want to get the auto and everything for it including cluster and column and give him all my manual stuff. I can make adjustments on my side when the time comes for it to go in. I just want him to get what he needs and be happy. Eventually the auto will be a core for a bts for me
post #4 of 16 (permalink) Old 05-08-2011, 04:22 AM
roughneck0913's Avatar
harnesses will not interchange IIRC
Sold---2000 f-250 4x4 cclb 6 pos tuned by cale airdog 250, holding a stock tranny. afe cold air few other tricks under the hood always
2008 F-250 CCSB 4x4 ZF-6 deleted from day 3
roughneck0913 is offline
post #5 of 16 (permalink) Old 05-08-2011, 06:37 PM Thread Starter
swamp_ratt's Avatar
Also need to know if my flywheel will bolt to his crankshaft and what about the trans adapter thats on my motor? Will he need that on his motor?
post #6 of 16 (permalink) Old 05-08-2011, 10:56 PM Thread Starter
swamp_ratt's Avatar
Bump... he wants to do this asap
post #7 of 16 (permalink) Old 05-09-2011, 06:15 AM
Confirm the flywheel mounting, earlier ones had 9 smaller bolts, my '97 has 10 larger ones plus "dowel / roll pin"
If that deal doesn't work out I might be able to help you out.
tysonxj is offline
post #8 of 16 (permalink) Old 05-09-2011, 08:42 PM Thread Starter
swamp_ratt's Avatar
My truck is a 95
post #9 of 16 (permalink) Old 05-10-2011, 12:24 AM Thread Starter
swamp_ratt's Avatar
Bump... need to know details before we drop the trans outta his truck. He daily drives it and cant afford down time. Just need to know if my set up will bolt right in his and be good to go.
post #10 of 16 (permalink) Old 05-10-2011, 01:59 AM
STILL LEARNING
Bradbilt's Avatar
NO. A PSD flywheel will NOT bolt up to,a IDI
Bradbilt is offline
