Help me diagnose my problem- Win free Transcommand:) Pictures Inside - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 05-07-2011, 06:44 PM Thread Starter
I have a miss that only occurs sometimes. Erratic idle, throws no codes. Does give me a couple CCT balance faults.
I have replaced so far-
ICP sensor and Connector
CPS
Fuel Pump
I have checked UVCH and ohmed out the engine harness
I checked for air in my fuel
Swapped IDMs
Pulled the Chip out
Cleaned FPR
Cleaned Fuel Bowl
The miss is very bad sometimes in the morning, it will lope and almost die. Seems to run just fine sometimes, mostly when its warm.
Heres a video of my fuel pressure fluxuating, no BB. Is this normal?
1997 F-350 Crew Cab Long Bed SOLD
2008 F-350 CCLB King Ranch- Spartan Tuned, Exhaust, Intake
Flippincgfighter is offline
post #2 of 30 (permalink) Old 05-07-2011, 07:01 PM Thread Starter
Re: Help me diagnose my problem- Win free Transcommand:) Pictures Inside
Here is what the scanner looks like at different RPM levels.
IPR looks kinda high at idle doesnt it? anything else look outa whack?
post #3 of 30 (permalink) Old 05-07-2011, 07:03 PM Thread Starter
post #4 of 30 (permalink) Old 05-07-2011, 07:04 PM Thread Starter
post #5 of 30 (permalink) Old 05-07-2011, 07:09 PM Thread Starter
WOT
post #6 of 30 (permalink) Old 05-07-2011, 07:53 PM
OEM Moderator
Tom S's Avatar
You fuel pressure bounces alot more then mine did when I had factory set up but rmine had a long hose to dampen the pulses.
Your IPR does look high to me.
If it was mine, I would probably replace the UVC harnesses and VC gaskets. I would then want to watch with the engine running looking for how the oil flows out of each injector.
My guess is you have an injector issue in the end result.
Tom S is offline
post #7 of 30 (permalink) Old 05-08-2011, 10:04 PM
gnxtc2's Avatar
Ohm out your injector solenoids.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #8 of 30 (permalink) Old 05-09-2011, 04:24 AM Thread Starter
I ohmed out my injector solenoids already, they all came in at 3.4 Ohms.
post #9 of 30 (permalink) Old 05-09-2011, 08:13 PM
strokeorcroak's Avatar
You say the injectors arent stock, they were remans at some point. So lets just assume they are all good, i guess the only other thing remaining would be the IPR. When the oil is cold maybe its not letting it pass through correctly!?
1996 with 35s
615hp/1258tq on 9/19
strokeorcroak is offline
post #10 of 30 (permalink) Old 05-09-2011, 08:20 PM
Chillin's Avatar
Lube oil for 500 Alex.
Check it.
And if you have a harness problem with the UVC or any other injector open circuit issue you WILL have a SES or CEL. If there's no light, you don't have problems there, or the bulb burned out.
Chillin is offline
