D-60 KP/BJ interchangeability question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 05-07-2011, 12:42 PM Thread Starter
I have a 94 Balljoint SRW Dana 60 out of a parts truck. I want to take this axle and make it a DRW. I have located the 4x4 DRW hub adapter out of an 89 Kingpin F350.
Are the 4x4 DRW hub adapters interchangeable between Balljoint and Kingpin?
lossscause is offline
post #2 of 16 (permalink) Old 05-07-2011, 01:49 PM
OBS junkie
Cat_Rebel's Avatar
Re: D-60 KP/BJ interchangeability question
Yep, the SRW/DRW hubs interchange on the different years, 86-97 D50/D60.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #3 of 16 (permalink) Old 05-07-2011, 02:02 PM Thread Starter
What's the procedure for removing these hubs? I'll have to bring tools with me to get them off this guys truck.
post #4 of 16 (permalink) Old 05-07-2011, 02:14 PM
OBS junkie
Cat_Rebel's Avatar
Pull the lockout hubs & bearings off like you were changing the rotor. It will all come off as one unit. Then unbolt the hub from the rotor & install onto your net rotor.
RIP Will Iott
post #5 of 16 (permalink) Old 05-07-2011, 10:10 PM
STILL LEARNING
Bradbilt's Avatar
Garret, are you SURE on this? I was told there was a spacing difference between a KP and BJ dually adapter. Or possibly it was pin style caliper to a bolt on style caliper
A minor difference that you can't see with your eye, but if you bolt on a KP dually hub to a BJ axle, the rotor hits the rotor mounting flange. Or maybe it was the other way around
Bradbilt is offline
post #6 of 16 (permalink) Old 05-08-2011, 04:07 AM
OEM Moderator
Tom S's Avatar
Are the knuckles interchangeable between a 97 F250 and a F350?
How about the caliper bracket and the outer stub shafts? I know the spindles are different.
Tom
Tom S is offline
post #7 of 16 (permalink) Old 05-08-2011, 06:44 AM
OBS junkie
Cat_Rebel's Avatar
Hmmm, I can't say for sure then Brad. I figured if the SRW hubs are the same then the duallys should be as well but I donno.
RIP Will Iott
post #8 of 16 (permalink) Old 05-08-2011, 02:28 PM
STILL LEARNING
Bradbilt's Avatar
Tom
I am told the knuckles are different. I know the axle stubs are different, and not sure of the caliper bracket
Like i said, that is what i was told, but not sure how true it was. But the guy who told me that has about 15 c-n-c trucks that he does all of his own servies to so....
Bradbilt is offline
post #9 of 16 (permalink) Old 05-08-2011, 03:23 PM Thread Starter
The deal fell through.
But it would be nice to find a definite answer to this. It'd be a pain to fid out the hard way that they don't interchange.
post #10 of 16 (permalink) Old 05-08-2011, 03:26 PM
OEM Moderator
Tom S's Avatar
Ok just wanted to know where I am headed. I finally got to tinker with mine gettiing it stripped down and cleaned up. The spindle bearing on one side has a lot of slop so I am betting new stub shaft on that side.
Tom S is offline
