Need help with truck running rough - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-07-2011, 03:57 AM Thread Starter
bluedge8's Avatar
Ok so here is the story, my truck has been running great. I went down to help out another member with his truck about 45mins from me. so when I got there I disconnected my batteries, pulled the Idm, swapped it into coreys truck and fired that truck, it got it running but not well. I pulled his Idm and put it in my truck and mine seemed to run fine. I pulled 2 relays out of my truck and swapped them around in his truck to see if it made any difference, it didn't. I put all of my stuff back in my truck and headed home, the truck seemed to run rough but not horrible,,,,,,, but by the time I got home it was barely running and would hardly go 50 mph. when I got home I cleaned the negative batt terminals I had pulled, took the Idm back out and re installed, and pulled the relays back out and switched them around, (same part #'s) truck barely starts now. I got a P0196, P1111, one of which I did when I did a buzz test, but those codes are not in the tech library. So common sense says that something I messed with is now acting up. Any help is appreciated.
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #2 of 8 (permalink) Old 05-07-2011, 03:59 AM
Haters Gonna Hate
Fordfreak4life's Avatar
Re: Need help with truck running rough
Make sure your IDM is getting a good ground
Fordfreak4life is offline
post #3 of 8 (permalink) Old 05-07-2011, 04:04 AM Thread Starter
bluedge8's Avatar
I did take a wire and jump between the case and negative with no change, but I might actually run a permanent wire between the 2, I wonder if somehow I interrupted a good ground path somehow???? fml
bluedge8 is offline
post #4 of 8 (permalink) Old 05-07-2011, 04:06 AM
Haters Gonna Hate
Circuit boards are funny things man
post #5 of 8 (permalink) Old 05-07-2011, 04:23 AM Thread Starter
bluedge8's Avatar
thanks for checking in, btw the superchips is sold so the truck has no tuning at all right now.
bluedge8 is offline
post #6 of 8 (permalink) Old 05-07-2011, 04:24 AM
Haters Gonna Hate
if you need anything pm me or lostcausepowerstroke he's my counterpart and has a pretty good knowledge of the 7.3
post #7 of 8 (permalink) Old 05-07-2011, 04:36 AM
gracing's Avatar
P0196 - engine oil temp sensor circut performance
P1111 - system passed no system faults detected
SWAMPS DIESEL PERFORMANCE
DIESEL INNOVATIONS
PERFORMANCE TRUCK PRODUCTS
EMPIRE DIESEL PERFORMANCE
gracing is offline
post #8 of 8 (permalink) Old 05-07-2011, 10:41 AM Thread Starter
bluedge8's Avatar
thanks for that, I may need to,,,, we'll see.
thanks, didn't see them in the list I was looking at.
bluedge8 is offline
