Getting ready to set in a used motor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-07-2011, 01:35 AM Thread Starter
What all would you replace while you have the engine out?
I'm thinking, Oil Rail End Seals, I'll be putting my turbo on it, Up Pipe donuts? Exhaust Manifold gaskets, Oil cooler O rings.
Anything else that comes to mind?
loudmouth is offline
post #2 of 2 (permalink) Old 05-07-2011, 02:54 AM
blageurt's Avatar
Re: Getting ready to set in a used motor
Glow Plugs , Injector o-rings , flush the block out thoroughly ..... I would personally install bigger intake plenums also take a real long look at the oil pan and replace it if needed... If it's solid , I would definitely sand it down and give it a few good coats of POR 15 engine enamel or similar paint to restore it....
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
