d50 to d60 brakes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 05-05-2011, 11:29 PM Thread Starter
BIG_RED
BIG_RED's Avatar
d50 to d60 brakes
will my calipers work with a '90 ball joint dana 60?
1996 F250:
-5spd w/4.10's
-3" dp to 4" straight pipe
-SouthBend ConOFE clutch
-K&N cone filter
-EBPV brake
-ISSPRO Gauges
-Custom E-Fuel
-Dana 60
-And now a custom front right fender.......
BIG_RED is offline
post #2 of 14 (permalink) Old 05-06-2011, 02:08 AM
Re: d50 to d60 brakes
Nope. You need new calipers and pads due to the different way that they bolt up. I just did this on my 90 King pin axle, are you sure is a ball joint? If it is then its a 92+ but even then you would need a 95-97 dana 60 to swap your calipers over.
02 f250
countryboyrob is offline
post #3 of 14 (permalink) Old 05-06-2011, 02:39 AM
STILL LEARNING
Bradbilt's Avatar
If your dana 60 is really a 1990, then it is king pins(not ball joints) and uses pin on style calipers.
Your 96 dana 50 uses the bolt on style caliper and will NOT work
Bradbilt is offline
post #4 of 14 (permalink) Old 05-06-2011, 04:53 AM Thread Starter
BIG_RED
BIG_RED's Avatar
its either an 89 or a 90. just trying to see what parts i need to pirate off the donor truck
1996 F250:
-5spd w/4.10's
-K&N cone filter
-EBPV brake
-ISSPRO Gauges
-Custom E-Fuel
-Dana 60
BIG_RED is offline
post #5 of 14 (permalink) Old 05-06-2011, 10:11 AM
STILL LEARNING
Bradbilt's Avatar
There is not too much you can use besides the hubs and locking hubs
Bradbilt is offline
post #6 of 14 (permalink) Old 05-09-2011, 12:25 AM Thread Starter
BIG_RED
BIG_RED's Avatar
basically im getting the 60 from the guy and i get all the suspension components as well. will my driveshaft match up to the front diff yoke?
1996 F250:
-5spd w/4.10's
-K&N cone filter
-EBPV brake
-ISSPRO Gauges
-Custom E-Fuel
-Dana 60
BIG_RED is offline
post #7 of 14 (permalink) Old 05-09-2011, 12:39 AM
Yes.
02 f250
post #8 of 14 (permalink) Old 05-09-2011, 01:46 AM Thread Starter
BIG_RED
BIG_RED's Avatar
and i can just connect my brake lines to the '90 calipers?
1996 F250:
-5spd w/4.10's
-K&N cone filter
-EBPV brake
-ISSPRO Gauges
-Custom E-Fuel
-Dana 60
BIG_RED is offline
post #9 of 14 (permalink) Old 05-09-2011, 01:51 AM
Yes.
02 f250
post #10 of 14 (permalink) Old 05-09-2011, 01:57 AM
gnxtc2's Avatar
The angle of the ends are different.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
