WHAT THE #$%^ - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 05-05-2011, 06:49 PM Thread Starter
Can a 1 ton do a wheelie?
purple_heart_350's Avatar
WHAT THE #$%^
Ok here is the deal, I just replaced the fuel pump and fuel filter on the truck last week. This week my fuel filter light will come on when when I go WOT but when I let off the light would turn off. Then out of no where the light came on and the fuel pressure dropped to 0. My quick thinking I switch tanks hopeing that the truck would still run. Will the light turned off and my pressure went back up to 55 psi. What the hell is going on here? I am lost.
'95 F350
IDM mod, FPR shim, 3 1/2" DP and CAT delete, aFe Big Boost, Quad pod-autometer Z seires gauges, 4" straight pipe exhuast, TS 6 position chip from KT performance
"Would it kill you to buy american" Clint Eastwood
purple_heart_350 is offline
post #2 of 11 (permalink) Old 05-05-2011, 07:03 PM
I know nothing...
joedaddy's Avatar
Re: WHAT THE #$%^
Screen between FB and reg? Dirty reg?
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #3 of 11 (permalink) Old 05-05-2011, 07:03 PM
OBS Addict
7.3psd97444's Avatar
Re: WHAT THE #$%^
hmm. have ya switched back to the first tank to see what it would do?
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #4 of 11 (permalink) Old 05-05-2011, 07:13 PM Thread Starter
Re: WHAT THE #$%^
no not yet I was on the way back to work and I didnt want to get stuck on the highway, and then have to be towed home.....again , I will do it down the street from the house.
why would it run fine again if I switched tanks. is there something in the tank that feeds the fuel pump that could have gone bad like a fuel pick up or something?
'95 F350
post #5 of 11 (permalink) Old 05-05-2011, 07:26 PM
Re: WHAT THE #$%^
Are you sure the tank is full? Could be the sending unit is bad and the tank is actually empty?
1997 F-350 Crew Cab Long Bed SOLD
2008 F-350 CCLB King Ranch- Spartan Tuned, Exhaust, Intake
Flippincgfighter is offline
post #6 of 11 (permalink) Old 05-05-2011, 07:29 PM
I know nothing...
joedaddy's Avatar
Re: WHAT THE #$%^
Sorry, I misunderstood. Fuel pickup may be comprised or line to tank.
joedaddy is offline
post #7 of 11 (permalink) Old 05-05-2011, 11:24 PM Thread Starter
Re: WHAT THE #$%^
I filled up friday, both tanks, havent gone 100 miles yet
'95 F350
post #8 of 11 (permalink) Old 05-05-2011, 11:28 PM Thread Starter
Re: WHAT THE #$%^
well I switched tanks again down the rod from the house and the fule filter light came on 5-10 seconds after the switch but fuel pressure was about 40-45 psi. I did it about a mile from the house so I am going to try and do it a bit further later t see if it will loose pressure.
'95 F350
post #9 of 11 (permalink) Old 05-15-2011, 05:20 PM
Re: WHAT THE #$%^
I'm having similar issues but is happening on all of my tanks. My fuel pressure regulator screen is clean this time. Thought it was the culprit before as it was completely clogged. But it is wide open now and 100 miles later same issue. Hopefully you can figure it out. Might help me as well.
addicted56 is offline
post #10 of 11 (permalink) Old 05-16-2011, 02:26 AM Thread Starter
Re: WHAT THE #$%^
dropped the tank and there is algie in the tank going to get new tanks
'95 F350
