Power Steering tightening - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-05-2011, 05:37 AM Thread Starter
Krause's Avatar
Hey Guys,
I read on 'Gaz's' site something about tightening up the steering pump, which may take some slop out of the steering; however it wasnt covered in detail how exactly to go about it. Did a quick search and didnt find what I was looking for, anyone have know what to do for this?
Thanks,
Krause
96 XLT ECLB. 6.0 intercooler. 4" aero turbine, gearhead tunes. Coolant filter & CCV mod. SD Dana 60 3.73 3.5 RSK V-codes, 35 inch toyos, 18inch M/T classic locks. 260000Km
Krause is offline
post #2 of 3 (permalink) Old 05-05-2011, 08:45 AM
Re: Power Steering tightening
Step 1- Acquire 5/8 end wrench, stubby wrench is easier to work around, as well as a 3/16 allen wrench i believe are the sizes
Step 2- Jack up the front end of the pickup, but do not interfere with tie rods or any steering mechanisms. Make sure it turns freely each way completely.
Step 3- Find the steering box, its on the drivers side, at the end of the steering shaft, just under the powersteering pump. On top there is a allen screw with a holding nyloc nut around it, loosen the nyloc nut and tighten the allen screw a little bit at a time while holding the nyloc nut.
Step 4- Once you tighten half a turn to one turn, turn the wheel both directions completely and make sure the box doesnt bind. If your steering is as loose as mine, it will need to be tightened a ways. My screw is all the way in.
* Before you do this, remember that it may blow some Power steering fluid out as it gets tighter, so remove the lid, and put a rag in there to soak some of it up.
1997 F-350 Crew Cab Long Bed SOLD
2008 F-350 CCLB King Ranch- Spartan Tuned, Exhaust, Intake
Flippincgfighter is offline
post #3 of 3 (permalink) Old 05-06-2011, 05:21 AM Thread Starter
Krause's Avatar
Thank you sir, just what I was looking for! Much appreciated.
Regards
Krause
Krause is offline
