turbo blow off valve? wastegate? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 05-05-2011, 03:55 AM Thread Starter
sixpack's Avatar
on gas engines with turbos they have aftermarket cool big ass blow off valves that make that sweet "pist" sound , what do our trucks have? or what do others do to theirs? sorry im just a noob
sixpack is offline
post #2 of 23 (permalink) Old 05-05-2011, 03:37 PM
blageurt's Avatar
Re: turbo blow off valve? wastegate?
Th wastegates are on the 99 and up Superdutys ..First gen trucks control boost by de-fueling electronically by the PCM and the various sensors
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #3 of 23 (permalink) Old 05-05-2011, 11:36 PM
OBS F350's Avatar
96 F350 zf-5, Rosewoods, 6637, mbrp, southbend, autometer, Rough Country. SOLD
08 f250 auto, dpf/egr delete, afe intake, Gearhead tunes
:, cold side pipe and cfm+ intake elbow.
OBS F350 is offline
post #4 of 23 (permalink) Old 05-06-2011, 03:51 AM Thread Starter
sixpack's Avatar
no fun
sixpack is offline
post #5 of 23 (permalink) Old 05-06-2011, 02:41 PM
SIZE MATTERS
7.3-StRoKeR's Avatar
If you want to put a blow-off valve on a powerstroke your a fag. Sell you truck and buy a Honda.
- 96 F250 XCSB PSD Auto 255,000 mi -
- 96 F350 CCLB PSD 5spd 98,000 mi-
3" Body lift and Leveling Kit
285/75-16 Federal Couriga Mt
3" DP to 4" to 8" Cat Stack
TS 6 Position Chip
GlowShift - EGT, Boost and Trans
CCV Mod
FRP Shim
EBPV Brake
AirLift Bags
To Come.........
4X4 Conversion, Stage 1's, E-Fuel, Adrenaline HPOP, Intercooler
7.3-StRoKeR is offline
post #6 of 23 (permalink) Old 05-06-2011, 02:47 PM
samdust's Avatar
Send a message via MSN to samdust
do you know how loud a bov would sound on a truck pushin like 100lbs. damn. but no i have wrx and the stock recirculation valve is loud enough, very annoying.
2001 f-250,7.3,4x4,cc
CORNFED RANGER
samdust is offline
post #7 of 23 (permalink) Old 05-06-2011, 03:38 PM
rolsmojave3's Avatar
Blow off valves are needed on gassers because they have a throttle plate that closes, blocking airflow, so you need to loose that boost.
97' F-350 7.3 5 speed, 160cc Rosewoods, 315/75r16s 16x10 MT fakelocks
96' F-350 7.5 5 speed, cali truck, 315/75r16s on Alcoas
02 Ranger FX4
79 "F350" mud truck, 18.5/44-16.5s
rolsmojave3 is offline
post #8 of 23 (permalink) Old 05-06-2011, 06:58 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
OBS do not defuel like the SD trucks do... With a OBS you would be hard pressed to overboost one... 1.15 exhaust housing and 90cc injectors mean 17-22# boost MAX.
A little harsh...
Joe
CSIPSD is offline
post #9 of 23 (permalink) Old 05-06-2011, 09:15 PM
Even if you have a chip or tuner? My truck can run up to about 32psi. I've been wondering if the previous owner did anything other then the tuner.
02 Ranger FX4
post #10 of 23 (permalink) Old 05-06-2011, 09:54 PM
95powersmoker's Avatar
CSIPSD's numbers were for a stock truck.. You can hit high 20's to 30ish with a tuner...
He is correct though, OBS trucks do not defuel at a certain boost pressure.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
