oil leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-04-2011, 10:26 PM Thread Starter
oil leak
I have an oil leak!! a really bad one the vally pan is pretty much dry. the oil is leaking between the motor and the bell housing. the hpop was replaced and was leaking but the vally pan stays dry and aint leakin oil out the drain under the turbo pedestol any ideas would be appreciated!!
storker95 is offline
post #2 of 6 (permalink) Old 05-04-2011, 10:48 PM
Edward Scissorhand WanaB
Bushwakd's Avatar
Re: oil leak
Have you check the oil dipstick flange? Use some rags and wipe off as much of the wet oil as you can. Start the truck and lay under neath the truck and look at where the dipstick enters the oil pan.
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #3 of 6 (permalink) Old 05-05-2011, 02:17 AM
BIG_RED
BIG_RED's Avatar
Re: oil leak
thats where mine is leaking from. what needs to be replaced on the dipstick flange
1996 F250:
-5spd w/4.10's
-3" dp to 4" straight pipe
-SouthBend ConOFE clutch
-K&N cone filter
-EBPV brake
-ISSPRO Gauges
-Custom E-Fuel
-Dana 60
-And now a custom front right fender.......
BIG_RED is offline
post #4 of 6 (permalink) Old 05-05-2011, 03:51 AM
OBS Addict
7.3psd97444's Avatar
Re: oil leak
Check the oil rail plugs.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #5 of 6 (permalink) Old 05-06-2011, 06:06 AM Thread Starter
Re: oil leak
The oil pan ended up having a hole in it from the bell housing access pan vibrating against it just took puttin the truck on a lift and pull the access off but thanks guys!!!
post #6 of 6 (permalink) Old 05-06-2011, 01:48 PM
OBS Addict
Re: oil leak
Right on glad you got it figured out.
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
