Fuel Pressure-No FPR Shim - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 05-03-2011, 05:18 AM Thread Starter
Question Fuel Pressure-No FPR Shim
What should fuel pressure be at idle on a unshimmed stock OBS FPR?
Mine sits right at about 50 psi, is this too low??
1997 F-350 Crew Cab Long Bed SOLD
2008 F-350 CCLB King Ranch- Spartan Tuned, Exhaust, Intake
Flippincgfighter is offline
post #2 of 26 (permalink) Old 05-03-2011, 08:46 AM
excavator's Avatar
Re: Fuel Pressure-No FPR Shim
that is good at idle however I had 50 at idle and dropped below 30 when pulling a trailer and lost power and boost would not get over 10. I changed the fuel pump and all power and boost came back.
96 F250 XLT 4x4 210000 miles Dana 60, Baby Swamped,Tony Wildman tunes,AutoMeter Pyro Boost Trans ,DPP downpipe,Tymar intake BTS TRANS
e99 f350 cc/lb drw php hydra plus Tony Wildman tune
excavator is offline
post #3 of 26 (permalink) Old 05-03-2011, 02:10 PM
OBS Addict
7.3psd97444's Avatar
Yeah 50 is good at idle. If your worried about something rig up gauging that you can see while driving. This is to check and see if your loosing pressure. Which like said above means your fuel pump is bad.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #4 of 26 (permalink) Old 05-03-2011, 07:02 PM Thread Starter
Yesterday when i checked it, it was bouncing between 50-55 psi. Fluttering, but a short range of PSI. Last night i drove it a bit and checked it again, and at idle it was bouncing between 40-50 PSI. Now this morning its fluctuating a lot more from 30-50psi at idle. Any ideas? Seems like pretty low PSI to me.
post #5 of 26 (permalink) Old 05-03-2011, 07:09 PM
strokeorcroak's Avatar
Gibson it sure seems low to me. The pressures shouldnt bounce like that, maybe because the pump is cam operated that it fluxuates in pressure, but it doesnt seem right to jump 10psi.
Where could air be getting into that system to cause the pressure to jump around??
1996 with 35s
615hp/1258tq on 9/19
strokeorcroak is offline
post #6 of 26 (permalink) Old 05-03-2011, 07:16 PM
I know nothing...
joedaddy's Avatar
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #7 of 26 (permalink) Old 05-03-2011, 07:23 PM Thread Starter
Next step is to check for air. Thanks guys!
post #8 of 26 (permalink) Old 05-03-2011, 07:31 PM
I dont really know where the air could be getting in though!? I didnt mess with the mechanical setup much before i swapped over so i feel like an idiot here...
Could the pump be failing and pulling air into the system? Seems like thats the most logical piece in my mind.
Theres not much room between filter/pump/heads for air to get in there, and it would have to be on the suction side.
1996 with 35s
post #9 of 26 (permalink) Old 05-03-2011, 07:56 PM Thread Starter
Selector valve? Maybe around the tanks? Im gonna put a clear hose between the pump and bowl, and im guessing ill find air bubbles. If i do ill start tracing the lines back. Arent they steel most of the way back? Weird thing is that it doesnt have a leak anywhere, and the running bad problem is sparratic. It hasnt ran bad yet since i put the gauge on. Ill be curious to see the fuel pressure when it misses bad.
post #10 of 26 (permalink) Old 05-03-2011, 08:00 PM
Yeah it only runs bad when your NOT trying to fix it haha.... Hence why it ran like a charm up at my place.
But the lines are steel all along the frame rail, they are rubber from frame to tank and from frame to engine. But even the rubber ones are steel enforced lines, doesnt seem like they would randomly start pulling air!
I bet its up in the valley somewhere
1996 with 35s
