slight blue smoke from a 7.3 powerstroke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 05-03-2011, 02:18 AM Thread Starter
got a 1994 powerstroke and there is a slight bit of blue smoke with black the truck does have a chip in it and i notice that it smokes less blue when in stock when reved im wondering if the fuel filter may need to be changed? it also has a slight blue haze when its warming up in the morning
94 Powerstroke, 3 inch lift, 3"DP 4" straight pipe to 5" in bed T then to 6" Ausie stacks, DIY intake large Baldwin air filter , Ts 6 position chip custom tunes,3:54 rear end 5 speed trans Rollin on 35" procomp extreme terrains
bigred94 is offline
post #2 of 19 (permalink) Old 05-03-2011, 04:06 PM
Sodbuster Jr.'s Avatar
Re: slight blue smoke from a 7.3 powerstroke
The slight blue haze during warm-up is understandable. When these trucks are cold the timing is advanced to allow for a little more fuel, and that blue smoke is just some unburnt fuel. Pretty much any diesel I have seen has a slight blue haze during warm-up. As far as when you rev it, it may have one or two injectors that are getting worn out. Does it start hard when its cold? Cause that could signal an injector or two are bad.
1996 F250HD 4x4, 270,000 miles, E4OD, 6637 Intake, Downpipe, 4in. MBRP w/muffler, 1705 Superchips, EBPV exhaust brake, CCV Mod, more to come...
1995 Dodge Ram 1500, 450,000 miles, Original engine (never been touched), Second transmission (Stage 2
), 6637 Intake, 4in. MBRP...after Flowmaster Series 40
Sodbuster Jr. is offline
post #3 of 19 (permalink) Old 05-04-2011, 06:01 AM Thread Starter
yea gotta cycle the glow plugs a few times and if i just do it once it'll blow a big cloud of white smoke however i did change my fuel filter and it brought down my fuel pressure so im assuming that the other was dirty and plugged
bigred94 is offline
post #4 of 19 (permalink) Old 05-04-2011, 01:50 PM
OBS Addict
7.3psd97444's Avatar
Speaking of fuel pressure what psi did you see. The little bit of blue is normal. How cold is it when you have to cycle the gp's a few times? Could have a bad relay.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #5 of 19 (permalink) Old 05-04-2011, 10:39 PM Thread Starter
its boucning around 45 psi goes up to 50 when i give it throttle use to be at 60 when the fuel filter was clogged and if its all warmed up and i give it a rev it blows blue or if im driving and get on it hard in say second or 3rd gear id say 40's i live in portland oregon i usually cycle em twice however with the chip in it makes the glow plug light hardly stay on also checked the blow by and it seemed to be puffin out more than im use to seeing but idk maybe i should make a video and put that up?
bigred94 is offline
post #6 of 19 (permalink) Old 05-05-2011, 03:53 AM
OBS Addict
Videos always help.
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
post #7 of 19 (permalink) Old 05-05-2011, 04:53 AM
95powersmoker's Avatar
Fuel pressure is fine...
Sounds like you might have some glow plugs out or a bad GPR...
The blue haze could be injector o-rings. Was the fuel filter oil when you replaced it?
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #8 of 19 (permalink) Old 05-05-2011, 05:04 AM
psdguy97
psdguy08's Avatar
I have this issue too. When i'm running the truck in tune and i get on it i see some type of white or blue haze with the black smoke. Truck runs fine with no issues. My injectors are stock with 218,000. Injector time maybe?
95 F-250 ECLB
6637 air intake, 3 inch dp to 4 inch exhaust, EBPV delete, ccv mod, glowshift gauges ( fuel pressure, boost, trans temp, pyrometer ) Dp tuner ( no start, stock, 80hp econo, 60hp tow)
Cobra 29 classic w/nightwatch, Wilson 1000 magnet mount, weather guard backrack, code 3 lightbar.
psdguy08 is offline
post #9 of 19 (permalink) Old 05-05-2011, 06:11 AM Thread Starter
i sure hope not injectors the previous owner said the owner before him did them idk
bigred94 is offline
post #10 of 19 (permalink) Old 05-05-2011, 12:20 PM
psdguy97
psdguy08's Avatar
I was told from the last owner that they had been "serviced". Whatever the hell that means. I have recipes dating back to 97 of everything that has been done to my truck and there's nothing in there about serviced injectors.
95 F-250 ECLB
psdguy08 is offline
