Driveline Questions On 97 F350 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 05-02-2011, 10:08 PM Thread Starter
< Can I drive?!
wint's Avatar
I am looking for a front driveshaft and forward drive tcase yoke for my truck and havent had much luck. Im curious as to what will work for this. Ive found a driveshaft from a 1990 F350 C6 with a BW1356 case but idk if that'll bolt up to my rig. I have also located a front driveshaft from a 97 f-350 cab and chassis. I want to make sure what i get will work before i get it and am stuck with it. I also need the yoke, what will work on that and where is a good place to locate them? Thanks so much.
The Army wants you!
wint is offline
post #2 of 13 (permalink) Old 05-02-2011, 10:24 PM
STILL LEARNING
Bradbilt's Avatar
Re: Driveline Questions On 97 F350
Being your truck is a 97 is should have a 4407 t-case. so you need a front yolk from a 96/97 F350(doesnt matter cab-n-chassis or pickup)
As for the front driveshaft, it can be from a 85.5-97.
The 5spd and 4spd manuals will have the shortest driveshafts
the E4OD will have the longest.
i am not sure where the C6 falls into the mix.
If you look at NAPA or EBAY, you can find reman driveshafts for about $250.
or you can use a 1356 t-case from a 85.5-95. It will bolt right in place of your 4407 but you will also need the rear driveshaft as well
Bradbilt is offline
post #3 of 13 (permalink) Old 05-03-2011, 03:36 PM Thread Starter
< Can I drive?!
wint's Avatar
What is the joint called that is in the front driveshaft? Is it a CV? That is what busted. The ends are good. Any way to have it fixed?
The Army wants you!
wint is offline
post #4 of 13 (permalink) Old 05-03-2011, 10:07 PM
rusty1161's Avatar
Double cardan. Most driveline shops should be able to rebuild what you have described.
Rusty
1997 F250 CC/SB 7.3 PSD 4X4 XLT, 248,000 miles
rusty1161 is offline
post #5 of 13 (permalink) Old 05-09-2011, 02:46 AM Thread Starter
< Can I drive?!
wint's Avatar
So now i need to get a yoke for the t case. What are my options?
The Army wants you!
wint is offline
post #6 of 13 (permalink) Old 05-10-2011, 08:34 PM Thread Starter
< Can I drive?!
wint's Avatar
Bump!
The Army wants you!
wint is offline
post #7 of 13 (permalink) Old 05-10-2011, 09:28 PM
STILL LEARNING
Bradbilt's Avatar
You dont really have any options. You need a yolk from a 4407 f350 t-case, if you are going to run a F350 front drive shaft
Bradbilt is offline
post #8 of 13 (permalink) Old 05-10-2011, 09:44 PM
woodduck97's Avatar
Hey Daniel my buddy Mark (black974door) just had a recently had a accident with his F-350. Once he gets things figured out on the truck. Maybe we can sell ya the parts needed off it.
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
post #9 of 13 (permalink) Old 05-11-2011, 04:15 AM Thread Starter
< Can I drive?!
wint's Avatar
Hurry! Lol
The Army wants you!
wint is offline
post #10 of 13 (permalink) Old 05-11-2011, 08:01 AM
rusty1161's Avatar
Have you read this? BW 4407 output shaft yoke - PowerStrokeNation
Rusty
