Need some questions answered! You smart enough? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 05-01-2011, 08:24 PM Thread Starter
Famous words "Watch This"
ascrap2003's Avatar
Exclamation Need some questions answered! You smart enough?
Ok
95 PSD 300K 5 SPD 2WD
Misses from idle to 1200 rpm
Only a icp code with a new icp installed
Miss gets worse & better at times
Choppy exaust sound
Passed buzz & contribution. No other codes or lights. No smoke
Original HP Pump & Sticks
Usually idles a lil rough/surge at start up cold or warm for about 3 seconds.
2002 F350 SuperCab SRW Lariat, Hutch Mod, EBPV Delete, Straight Pipe, Chipped
2007 F550 Crew Flatbed
My websites:
ascrap2003 is offline
post #2 of 12 (permalink) Old 05-01-2011, 08:26 PM
PSA
mclean's Avatar
Re: Need some questions answered! You smart enough?
how are the UVCH's?
2010 F350. CCSB. KEM, Spartan, H&S, GearHead, Flo-Pro, S&B, NADP/RCD
mclean is offline
post #3 of 12 (permalink) Old 05-01-2011, 08:37 PM
OBS Addict
7.3psd97444's Avatar
hows the fuel pressure too?
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #4 of 12 (permalink) Old 05-01-2011, 10:02 PM
hpop oil pressure? worn injector,s low compression. hard starting? hows the somoke.
oldschool is offline
post #5 of 12 (permalink) Old 05-01-2011, 10:42 PM
OBS Addict
He said there was no smoke. just saying.
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
post #6 of 12 (permalink) Old 05-02-2011, 02:01 AM
F350-6's Avatar
Which ICP code? There are different ones that get tripped for different reasons.
Last oil change? Is it full? Type of oil?
Does the miss change if you unplug the ICP sensor?
What CPS are you running?
If you can read codes, can you do a contribution test?
2002 F350 6-speed 444 CID. XLT, Heated Seat, 495,000 & counting.
F350-6 is offline
post #7 of 12 (permalink) Old 05-02-2011, 09:33 PM Thread Starter
ascrap2003's Avatar
Exclamation Re: Need some questions answered! You smart enough?
First off dont have the exact code & I am getting tired of spending $100 everytime so do with what you know please.
95 250 PSD 300K 5 SPD 2wd
as for ICP code not sure which one but please figure what it would be with either of them
No other codes, lights, smoke etc.
Original HPOP & Sticks
Original drivers side uvc gaskets etc.
Original IPR that has been cleaned
Original CPS I think
What has been done?
Oil changed 2K ago Syn Rotella
New OIL press valve
#3 intake valve rocker bb replaced
IPR cleaned
New fuel pump & filter
Fuel housing cleaned
Turbo compressor inlet inspected seems good, clean no play
ICP sensor has been replaced
Pass side UVC all wires & gasket replaced & all ext inj pigtails replaced
Engine harness inj wires checked & replaced as neccesary
Last scan pass buzz, pass contribution
just that icp code
Symptoms:
start up cold or warm = choppy idle for 3 seconds 1/2 the time
cold engine seems louder
cold or warm = always misses sometimes more than others
also seems to clear up sometimes.
More power at 3/4 throttle than full throtlle
Feels similiar to a slightly plugged fuel filter on a gas motor when at full throttle
My websites:
post #8 of 12 (permalink) Old 05-02-2011, 09:39 PM
swamp_ratt's Avatar
the tin nut on your ipr loose? ohm your injectors. should be between 2.9 and 3.6 ohms iirc. can help rule out bad uvch's and vcgs as well.
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
post #9 of 12 (permalink) Old 05-02-2011, 09:42 PM
swamp_ratt's Avatar
also is your fpr screen clean?
post #10 of 12 (permalink) Old 05-02-2011, 09:49 PM
OBS Addict
Sounds like maybe a HPOP or injector issue based from it loosing power at wot but not at 1/2 or 3/4.
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
