rough idle and no power only for a second with CEL - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 04-30-2011, 04:59 AM Thread Starter
powerstroker66's Avatar
i seem to have a fuel or timing problem the truck will throw a check engine light and run really rough with no power for a second or two then be perfectly fine and no check engine light but sure as shoot does it again randomly within 5 min. I was thinking it was the CPS sensor but I'm not sure because it still has the mechanical fuel system and it might be the pump. It seems to be more and more frequent as i drive it so i didn't know if any of you guys have had the same problem. if not i will try to scan it tomorrow and see if it stored any codes.
powerstroker66 is offline
post #2 of 18 (permalink) Old 05-02-2011, 12:40 AM Thread Starter
Unhappy Re: rough idle and no power only for a second with CEL
it didn't have any codes and apparently it just stopped doing it all together. i didn't do anything, maybe water in the fuel, air bubbles, any ideas? i dont want it to happen again.
post #3 of 18 (permalink) Old 05-03-2011, 12:29 AM
blageurt's Avatar
Ipr tin nut tight ? Ipr Wiring solid ?
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #4 of 18 (permalink) Old 05-03-2011, 12:31 AM
<-Friends bike
WAG is UVCH burned . Fuel almost never sets a CEL (maybe a weak pump at WOT )
Scan it , most likely 1316 ( codes stored in the IDM )
A buzz test will give you the IDM codes ...
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
ActionRick is offline
post #5 of 18 (permalink) Old 05-03-2011, 03:27 PM Thread Starter
ok i will have to give it a try see whats going on haven't had time to look at it latley i will try sometime this week and let you guys know. Thanks for the help
post #6 of 18 (permalink) Old 05-04-2011, 09:10 PM Thread Starter
i can't get a scanner until tomorrow but i was thinking could it be a bad ICP valve that would make sense why it runs fine sometimes and not so good other times. If it was a sensor it would be getting progressively worse but it seems to have a pattern, CEL comes on once every mile or so then get worse until it does it 5 times in one mile then doesn't do it at all for a day then goes back to doing it. It's just annoying! any ideas?
post #7 of 18 (permalink) Old 05-04-2011, 09:16 PM Thread Starter
and i have herd of the wires and plugs getting burned under the valve covers so i will look into that as well. any specific things to look out for besides burnt plugs and frayed wires?
post #8 of 18 (permalink) Old 05-05-2011, 01:50 AM
blageurt's Avatar
Smell the oil cap for burn't plastic smell and since you are taking the covers off, torque the Injectors down ( 10 lbs-ft)
blageurt is offline
post #9 of 18 (permalink) Old 05-05-2011, 02:17 AM Thread Starter
alright will do ill keep you guys posted with what i find. thanks!
post #10 of 18 (permalink) Old 05-08-2011, 05:40 AM Thread Starter
ok i pulled the plugs going to the valve covers and 2 of the glow plug prongs are burnt so bad it is melting the plastic and it looks like it burned through the side wall insulation and started to interfear with cylinders 1 and 2 injectors. I also saw that the wiring harness has been messed with before so i am wondering if i should just get a new one and try to prevent any further problems down the road. I pulled the valves covers to take a look at no wires are rubing or loose conections so would this glow plug interfearance connection be the problem?
