Driveline Vibration - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 04-29-2011, 12:04 AM Thread Starter
BambiBasher's Avatar
Driveline Vibration
well iv noticed that iv had a vibration at my feet on the floor board. well i thought it was my front shaft cause we noticed the yoke was loose. well its out and damn vibration is there. its constant when your over 30mph. gets worse the faster you go. the only time it goes away is when you turn left or push the clutch in. other than that its there. the truck has 168,000 on it. i noticed it a lil bit after a truck pull last summer. i woulnt think the u joints would be bad. could it be in my trans or t case?
any ideas?
Thanks,
Jacob
1997 F350 7.3 PowerStroke Diesel
Regular Cab 4x4 ZF5
Straight pipe to 5 inch single mitre stack, 6637, SBC Clutch, Carson Stauffer Reg. Return fuel system, Banks 6 POS chip leavin soon
Future Mods:
250/200s
S400 or HX turbo turbo
Swamps 6 Pos chip
Goal is 1000 ft lbs of torque
3 inch DP
EGT, Boost, Fuel gauges
BambiBasher is offline
post #2 of 22 (permalink) Old 04-29-2011, 12:07 AM
swamp_ratt's Avatar
Re: Driveline Vibration
sounds like a u-joint given the symptoms
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
post #3 of 22 (permalink) Old 04-29-2011, 12:17 AM
stroked2000's Avatar
Poss a clutch issue if your saying it happened after a truck pull.
2000
f250 cc sb 4x4 4" lift 35s muffler delete, 6637 mod, beans tunes
stroked2000 is offline
post #4 of 22 (permalink) Old 04-29-2011, 12:24 AM Thread Starter
Swamp ratt- if u joint which one do you think? cause the front end shouldnt spin at all correct?
stroked2000- what do you mean clutch issue?
Regular Cab 4x4 ZF5
Future Mods:
250/200s
Swamps 6 Pos chip
3 inch DP
post #5 of 22 (permalink) Old 04-29-2011, 12:38 AM
swamp_ratt's Avatar
my guess would be that since it doesnt do it when turning its a front axle u-joint, but if your front end is not locked in and your transfer case is is 2 wheel drive your front end should not spin!
post #6 of 22 (permalink) Old 04-29-2011, 01:07 AM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
i bet its u joints. jack up the rear wheels and give it a wiggle. if theres any movement in the joint its toast. replace it there realitively cheap and easy
Refugee
pstroke96 is offline
post #7 of 22 (permalink) Old 04-29-2011, 10:19 AM Thread Starter
well when i turn left the vibration goes away. this weekend im gonna pull the rear shaft and see if that does anything
Regular Cab 4x4 ZF5
Future Mods:
250/200s
Swamps 6 Pos chip
3 inch DP
post #8 of 22 (permalink) Old 04-29-2011, 11:57 AM
Does the steering wheel re-center after you round a corner (like at a street intersection) or do you have to re-center it?
Vibrates on excelleration and deceleration? What about if you lightly apply brakes on excel and deceleration? As noted above put it on jack stands and check for play at all universals, pinion nuts, yokes and pillow block.
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #9 of 22 (permalink) Old 04-30-2011, 05:38 PM Thread Starter
jcart- it vibrates while accel and decel. the steering wheel recenters itself. next time i drive it ill try the brakes while accel and decel.
Regular Cab 4x4 ZF5
Future Mods:
250/200s
Swamps 6 Pos chip
3 inch DP
post #10 of 22 (permalink) Old 05-02-2011, 11:43 PM Thread Starter
well nothing changes while braking with accel or decel. but im starting to think that the vibration is coming from another area. i was sitting in the driveway and i could feel a slight vibration. revved it up and the higher i went the worse it got. the same one i had felt before. any ideas?
off topic but anyone know the socket size for the yoke on the front output of the t case? mine is loose and leaking. i have the sizes but they are all thick wall sockets.
Regular Cab 4x4 ZF5
Future Mods:
250/200s
Swamps 6 Pos chip
3 inch DP
