bed removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-28-2011, 08:39 PM Thread Starter
bed removal
Hey Guys, was wondering if anyones removed there bed and rode around with it off (im planning on doing some bed and rear area work).
I'd like to know a few things...
A) How do I remove the bed to start?
B) How do I fill my truck w/ fuel with the bed off?
C) Where's the easiest/best place to rig up lights and mudflaps (keep it legal).
Pictures too please, that'd be awesome, I'd like to see how my truck will look. Thanks.
tecster is offline
post #2 of 3 (permalink) Old 04-28-2011, 08:47 PM
Can a 1 ton do a wheelie?
purple_heart_350's Avatar
Re: bed removal
the nuts are under the truck dont remember the size, the fuel tanks should be mounted to the frame not the bed best way that I have seen light mounted was to a 2x4 zip tied to the frame and small trailer lights put on and the mud flaps screwed on to the 2x4 as well
'95 F350
IDM mod, FPR shim, 3 1/2" DP and CAT delete, aFe Big Boost, Quad pod-autometer Z seires gauges, 4" straight pipe exhuast, TS 6 position chip from KT performance
"Would it kill you to buy american" Clint Eastwood
purple_heart_350 is offline
post #3 of 3 (permalink) Old 04-28-2011, 09:05 PM
swamp_ratt's Avatar
Re: bed removal
6 3/4 inch nuts under the bed, 6 screws holding the fuel tank filler necks to the fuel door area, 2 hose clamps holding the filler necks to the underside of bed outside the frame rail, and unplug the light harness behind the back bumper next to the driver side frame rail on the rear cross member
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
