Intermittant Truck Issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-28-2011, 05:58 AM Thread Starter
Underfunded
moonshiner's Avatar
Send a message via AIM to moonshiner
Soo the issues started Sunday morning after I loaded the bike in the bed... The truck had a hard time starting and after it got going it would shut itself off, I'd turn the truck off and then it started up fine and after revving the engine a bit I took off an no issues...Till i shut it off waited 6hrs and tried to start it again then same issue...
On the drive home down the highway... The truck started to "knock" on the back cyclinders and a definite loss of power was felt, it started doing this quite frequently enough for me to worry I wouldnt make it the next 60miles home, I pulled over then pulled out the chip thinking that was the issue as it may have been the cause of my failed IDM a month before.
Started down the highway again and the truck kept up its intermittant "knock" and loss of power every 10-20 minutes...
Made it home then shut the truck off and let it sit a few days... it stocked the weird knock, but still starts really hard, and once it starts and I put it in drive it shuts off and then proceeds to make it difficult to start up, once its started and revved up to 2k for 60secs it'll drive fine, but without the chip in its gutless, almost feels more gutless than usual (without chip in)...
What the heck could this be? My idea's are: Valve Cover Harness (bad glow plugs could have caused a short), Bad electric fuel pump, bad regulator?? Any other ideas??
1996 F350: 4.10's Detroit Locked Front/Rear, Rampage Chip, SD/Racor E-Fuel, Adrenaline, 160cc's, Bell SS/66 Turbo, SD CAC, 315/75/16's Fierce M/Ts, 6" Lift, 6ft Traction Bars, 5" Stacks.
2007 Harley FXSTB: Bassani Prostreet Pipes, Terry Comp tuner, V&H Air Cleaner
2008 Honda Ridgeline RTX
2010 VW Jetta 2.5
SEMPER FI - USMC LT.
moonshiner is offline
post #2 of 6 (permalink) Old 04-28-2011, 07:44 PM
zilla68's Avatar
Re: Intermittant Truck Issues
any codes thrown?
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #3 of 6 (permalink) Old 04-28-2011, 08:32 PM Thread Starter
Underfunded
moonshiner's Avatar
Yes! My buddy has the list but I'll get em posted up when he rolls over!
2010 VW Jetta 2.5
post #4 of 6 (permalink) Old 04-28-2011, 11:27 PM Thread Starter
Underfunded
moonshiner's Avatar
Alright codes are as follows...
PO341: CMP Sensor Circuit
PO603: KAM (internal)
PO344: CMP Circuit Intermitent
PO470: Back Pressure Sensor Circuit
2010 VW Jetta 2.5
post #5 of 6 (permalink) Old 04-28-2011, 11:44 PM
excavator's Avatar
Might have bad cam sensor but I bet your ipr nut came loose or fell off
96 F250 XLT 4x4 210000 miles Dana 60, Baby Swamped,Tony Wildman tunes,AutoMeter Pyro Boost Trans ,DPP downpipe,Tymar intake BTS TRANS
e99 f350 cc/lb drw php hydra plus Tony Wildman tune
excavator is offline
post #6 of 6 (permalink) Old 04-29-2011, 06:20 AM Thread Starter
Underfunded
moonshiner's Avatar
Turns out Ford... can't sell/manufacture a proper CPS to save their lives... Plugged in my old sensor, I'm assuming it is the kind International sells, and truck runs fine... Chip however is staying out... but thats a different story.
2010 VW Jetta 2.5
