Clutch slip - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-27-2011, 01:58 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Clutch slip
Ok. so i put a different set of tires on my 97 tonight and i want to test drive it and see if they rubbed(they do).
For a little backgound. I bought my 97 about 2 months ago.
97 CCSB 7.3 5 speed 4:10s Napa air filter, DP f4 chip, rest is all stock. O and it is a Cali truck.
On the way home from buying it from the dealer, i wanted to see what the truck would do. Well i turned the chip up and goosed it. And the clutch slipped. It is fine with the chip in the 1st positon but beyond that the clutch slips. So I only have been driving it in the 1st position, till I put clutch in.
Anyway today I decided to turn my chip up and flog it a little. Well there was no clutch slip and I broke the tires loose in 2 gears, on clean gravel free road.
What gives?
Bradbilt is offline
post #2 of 9 (permalink) Old 04-27-2011, 02:03 AM
wrenchturner250's Avatar
Re: Clutch slip
Any idea what clutche it has in it? How old? Mine slipped about 3 months after I installed it... that being said never has slipped again.
2007 f250 Sd fx4
Arp's, 4"dp 5" straight pipe with 7" stack,S&B intake, no limit cold side, blue spring, 6.4 banjos, gauges, 2.5" leveling kit,sct with gearhead tunes, egr delete and coolant filter warren 175s, powermax
wrenchturner250 is offline
post #3 of 9 (permalink) Old 04-27-2011, 02:11 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Re: Clutch slip
Clutch is about 1.5 years old and 10k old
Bradbilt is offline
post #4 of 9 (permalink) Old 04-27-2011, 02:16 AM
Re: Clutch slip
I would say it would be okay but you never know is it a luk or sb or an oem? Cuz I'm running what's in my sig and my luk hasn't slipped yet and I haven't been super nice I hold back becuz of my turbo and hpop for now
2007 f250 Sd fx4
post #5 of 9 (permalink) Old 04-27-2011, 02:23 AM
Re: Clutch slip
Maybe the clutch was a little wet with oil when you bought it (rear main seal). Now that you drive it daily, it stays fairly dry.
For Sale: 2000 F350, black cc sb 4x4
Jngreen is offline
post #6 of 9 (permalink) Old 04-27-2011, 02:25 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Re: Clutch slip
It just just a OE clutch. There is a small leak of some variety up in the valley, but this is the first time i even started the truck in 2 weeks. I only have put 500 miles on it in 2 months The last time i had it out(2 weeks ago) the clutch slipped in stage 2
Bradbilt is offline
post #7 of 9 (permalink) Old 04-27-2011, 02:48 AM
Re: Clutch slip
Pull the inspection cover off and take a look see if its wet or just wore out, my dads psd has 90k on it never slipped and has an evo intake and exhuast but idk
2007 f250 Sd fx4
post #8 of 9 (permalink) Old 04-27-2011, 02:55 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Re: Clutch slip
There is no inspection cover that I know of
Bradbilt is offline
post #9 of 9 (permalink) Old 04-27-2011, 02:57 AM
Re: Clutch slip
There is you can't see a lot but you can see if its wet and how much is left
2007 f250 Sd fx4
